Filling the tank.... over the hood....
   / Filling the tank.... over the hood.... #1
tctx
Texas
Kubota B7800HSTF / RTV900 diesel 4x4
Okay... I'm making the operational plans for delivery next week of my X-Mas present (B7800)... and have read a few posts about fueling the tractors... but I'm having a hard time picturing myself lifting a 5 gal container of diesel fuel over the hood of my new tractor to fill it the tank... not that I couldn't lift the container...it's just the thought of spillage that I can't get by.... accidents do happen....
So... I'm thinking that someone has a place to get a mini-gas pump type handle for their diesel can.... you know... something with a hose and lever like at the gas station... but smaller.... any ideas? Does TSC carry these?
tc
man... my hands are sweatin'.... just a few more days....
   / Filling the tank.... over the hood.... #3
I had a few spills on the hood of my 4210 until I realized the best way to fill the tank was to put a heavy old towel atop any point the fuel container might scratch, then rest it on the towel and insert the spout into a good size funnel atop the filler opening. Then open the spout and the container vent.
This method works well for me with a 6 gallon container.
   / Filling the tank.... over the hood.... #4
I used to also place a towel on the hood of my old Bison to prevent scratching. I would then let the hood support the weight of the 5 gallon fuel container, open the spout insert it in the fill hole and lastly open the vent on the 5 gallon container. The process was always quick and spill free.
I think that you will tire quickly of the mini pump idea.
   / Filling the tank.... over the hood.... #5
I bought a poly 5 gallon yellow diesel can at Napa. This can has only one opening - a spout which will not pour or spill even if turned upside down until you also put weight on a flange on the spout. With this can you can put the spout into the tank without spilling a drop - then put weight on the flange - it rests on the lip of the tank opening. The air vent is part of the spout and there is a spring of some kind inside the spout. You can lock or unlock by turning the spout. Before I had this type of can I spilled fuel now I spill none. I looked all over to find a yellow can before finding this one at Napa. It was a bit costly - I think about $30.
   / Filling the tank.... over the hood.... #6
I had that problem too when I had my ford 1910 but I solved it when I bought my Century. It has the tank on the side by the step so you only lift the can waist high and don't spill ANY on the tractor. I am surprised that all Manufactures haven't thought of that. It even puts the wt. down low for better wt distribution.
leaddog
   / Filling the tank.... over the hood.... #7
Welcome tctx
Two ways (works for me):
I have a hose/nozzle on a 30 gal 'yellow' barrel that I get filled with diesel fuel, then just raise it with the FEL, and let gravity run the fuel into the tractor tank. Come spring, when usage goes up, I will fill the 30 gal barrel and use the gravity method.
In the winter, I just buy 3 gal at a time in the 5/6 gal container, and find it is easy to pour into the tractor tank without spilling or scratching. Lately, as the tractor is mostly just waiting for snow with intermittent firewood hauling, I find this method is adequate for the few hours I am putting on the tractor.
   / Filling the tank.... over the hood.... #8
Ok guys, I am not the brightest of the bunch, so I spilled some diesel on my blue jeans and hung them on the line. I did not realize that some diesel soaked into my boxers (not briefs) and I tossed them into the laundry basked.
So Sunday evening about 10 minutes after most of the stores in our area closed for the day, my loving wife, saint that she is, tosses ALL of my daughters Catholic school uniforms into the wash. And oh yeah, she also tossed some of my undies and socks into the washing machine. Well the diesel soaked boxers ended up in the wash with all school uniforms.
So about a New York second after the bell rang on the washing machine a shriek that would have scared a dinasour into extinction come from the laundry room.
Now most of the stores are closed, it is pushing 9pm on Sunday night, my 8 year old daughter has tears streaming down her face, she is clutching her stuffed animal and in total hysterics. The lovey wife is screaming at the top of her lungs, and there is no way that my "selective hearing" is going to work in this case.
Off to the only store in town that is open and I fill up a basket full of every possible chemical solution that might remove the smell.
To make a painful situation come to a quick conclusion, the answer turns out to be SIMPLE GREEN. When you spill diesel fuel on your tractor, and you will eventually do that, then make sure to shower in a stream of SIMPLE GREEN. It will take the diesel smell out of your clothes, because that spill on the hood of our machines will run down your leg and end up in the wash, if not with your kid's school clothes, then with that lovely lace tablecloth that grandma hand made or with some other priceless piece of cloth that some critical family member needs a lot more than they need YOU and your diesel stink.
Now to some of the other attempts . . . OXI CLEAN does not work. ORANGE cleaners do not work, LESTOIL does not work, PINE SOL does not work, TIDE does not work. About two in the morning we get to the SIMPLE GREEN and find that it did work.
AND IF YOU WANT TO TAKE GEAR GREASE OUT OF YOUR BLUE JEANS . . . you should use LESTOIL, but Lestoil has it own stink. You need the SIMPLE GREEN to remove the smell of the LESTOIL. But the LESTOIL will do a darn good job of removing the grease, it just leaves its own smell that you have to get rid of.
I can honestly say I don't know how to get TAR out of my clothes and after the whole episode with diesel smell I went to church and prayed that I am never within 30 yards of wet tar.
My advice to you is simple. You have tools, you have a tractor, and you have a family. Buy a large bottle of SIMPLE GREEN and a large bottle of LESTOIL. Keep them with your tools so you will be able to find them. Then, when you get greasy or when you spill that diesel, take the clothes to your lovely sainted better half, and take the S.G. or Lestoil & S.G. and explain that you are a man and that men are clumsy and sometimes get dirty . . . Because when momma is not happy then nobody is happy.
   / Filling the tank.... over the hood.... #9
I put a towel on the hood to set the can on and use one of those squeeze ball kerosene syphons one would use to fill a heater. They are cheap and work well.
   / Filling the tank.... over the hood.... #10
THIRTY DOLLARS !!! OUCH. I paid $7 each for the two Chilton brand yellow poly six gallon cans I found at Big Lots (also known as Odd Lots). Yes, it's difficult to find those yellow cans but I think it a good idea to use different can colors for different fuels. A few years back, some fellow I knew poured kerosene into his motorcycle by mistake. From that day on, any kerosene I purchased at the filling station went into a BLUE container....
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
378491 (A51572)
378491 (A51572)
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
