newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,974
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Finally got the bamboo cleared and am about to embark on setting 9 sono tubes for the shed base. As I've written before, the shed is inaccessible by concrete truck.
It's going to require 40 to 50 80lb bags or equivalent.
Since we are doing this on a very flexible schedule (only a few hours/day due to other demands) mixing w/ a mixer I own will be the way to go.
But reading up Quickcrete and Sakcrete it seems their bag mixes may be variable
And personal experience with bags recently that seemed to use well rounded, small river run gravel for the aggregrate.
At $4/ bag I'm wondering at the tradeoffs between doing it from raw material the way I did it in 1963 (one shovel cement, a few sand, a few gravel, add water) and buying the bags.
What's the TBN advice?
from Shop QUIKRETE 80-lb Gray High Strength Concrete Mix at Lowes.comJust did a small job with 10 bags of Quikrete. Two bags were not mixed correctly. One bag was completely unusable - the bag was nothing but cement (no sand or aggregate). 20% is not an acceptable failure rate.
Not my first experience with bad mixes ... used a Quikrete stone veneer mix for a previous job and gave up and returned everything. Mixes were way short on cement.
