Filling Rear Tires
   / Filling Rear Tires #1
Anonymous Poster
Epic Contributor
I have 55 lb. weights on the rear wheels of my Craftsman 18 HP tractor. I am planning to add a set of chains. Has anyone filled the tires on their garden tractor with windshield fluid? Would this be overkill?
   / Filling Rear Tires #2
Usually it's a one or the other proposition. Either fill the tires or get rear weights but not both.
Jim
   / Filling Rear Tires #3
My Ingersoll tires were filled. Now they are not becouse I just got a set of AG tires, and a set of wheel weights. I will play it by ear, and if I need more weight, I will fill them. Do you have the need fore more weight? Its only overkill if you don't need it.
   / Filling Rear Tires #4
Whatever you fill them with, be it CC or an antifreeze solution, install tubes so it doesn't affect your wheels. An ounce of prevention...................
   / Filling Rear Tires #5
Yes. Always use tubes if you fill. Tubes are cheaper then rims./w3tcompact/icons/smile.gif
   / Filling Rear Tires #6
We had a tractor like your with the 55 lbs. weights and chains. If you put the chains on, you won't need the fluid. It is amazing how much difference the chains make.
   / Filling Rear Tires #7
I filled the rear tires, and I use chains on my garden tractor. The filled rear tires really make the unit feel safer and more stable on side hills, while also aiding in traction. I still need the chains to mow some of the grades on my lawn. Without the chains, even with the differential locked, I couldn't make it up some of the grades. I ran a Toro 312H like this for 14 years, and just retired it when I bought a new Cub Cadet 3208 recently. For me, filling the tires and using tire chains is the only way to go.
Corm
Since I have the wheel weights I will not fill the rear tires, but will probably buy a set of chains for additional traction. Appreciate all of the feadback.
   / Filling Rear Tires #9
Hey Oldud,
I think I've got the same 18hp Craftsman that you do. I have the 55 lb weights, and I got them mainly for mowing hills. My Craftsman is about 16 years old, and it does a great job of holding the turf. I recently bought a 16 hp Wheelhorse from the early 80's, and my new (used) NH TC21D , and my Craftsman is still around. I love the way it cuts, and it didn't ever cost me a dime other than belts. I don't have a front blade, but I'd imagine that the tractor would push a bunch of snow with the chain, weights, and blade. Good Luck, I think you should have a great time pushing snow.
Kent
SteelFan - The Craftsman has been a good tractor. I bought a new Snapper riding lawnmower to replace the Craftsman. I have removed the mowing deck and have removed all of the parts to be used for future projects. I will use the Craftsman as a tractor with various sleeve hitch attachments. I just ordered a sleeve hitch from Sears. Once I get it and get it installed I am then going to buy a rear blade and probably a box scraper. Sears doesn't sell a snow blade to fit this tractor so I will have to try and locate one somewhere else. There may be other attachments that I will also purchase later after I see how the Craftsman does with the blade and box scraper. I have several ideas for modification to the tractor and may try and made some attachments. Will keep you posted.
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2016 Chevrolet Malibu Sedan (A51694)
2016 Chevrolet...
2011 Dodge Nitro SUV (A51694)
2011 Dodge Nitro...
