Ballast Filling Rear Tires on 1700
   / Filling Rear Tires on 1700 #1
fig
Thomasville, NC
yanmar 1700
Guys,
Don't mean to sound like an idiot, but do the rear tires on these machines have tubes? I have looked at the tires and they do not say tubeless, but the valve stem looks as if they could be. I am ready to fill the tires with windshield washer fluid and water. Also, how much windshield fluid / water would I put in?
I am going to use a drill pump and a 5 gallon bucket to do the deed. Any info is appreciated.
Fig
   / Filling Rear Tires on 1700 #2
No way to know about the tubes, except to look. Some do some don't. My YM2000 does. You could flatten the tire and see if the valve will push in.
Norm,
Are your rear tires filled? If so, how much fluid did they take?
Fig
   / Filling Rear Tires on 1700 #4
17 gallons for a 9.5x24, 13 for a 8.3x24.
LMTC,
Thanks for the info. I plan on doing it tomorrow.
Fig
   / Filling Rear Tires on 1700 #6
I use a brass adapter available at OSH. It hooks to your garden hose and valve stem, and has an air bleeder on it. Costs less that $10.00 from what I recall. I put the tire stem at 10 or 2 o'clock and fill about 3/4 full. Takes about 5 min each tire.
   / Filling Rear Tires on 1700 #7
hey there fig,
how'd this go? Did you do the "fill" yet? I'm curious, i'm thinking of doing this to my 1601, it was kinda scary on a hill yesterday and i figured that some ballast in the tires would help... thanx -arthr
   / Filling Rear Tires on 1700 #8
I purchased an adapter also. the adapter that I bought has an air bleed. Like Jim said I rotated so that the valve stem is at the top, connected adapter to garden hose & filled.You can in as much water as you want. Want to fill to the top with water ? Just keep letting the air out with the air bleed. May want to add anti freeze if stored outside in the winter.
Jim,
What does OSH stand for?
Fig
arthr,
Had every intension on doing this past weekend, but my wife had other plans for me. I guess I should have checked the to do list before I planned. Hopefully will get to some night this week or Saturday.
Fig
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
