<font color="blue">
The only reason that I am worried is because the dealer mentioned that he has had it happen before when filling tires. </font>
I believe the problem is a different rim profile between the 16" and 16.5" rims that are used on the Kubota CUTs. My
B2910 uses the rim that has a profile that tends to keep the tire on the rim without pressure in the tire. The step smaller B series has (if I remember right) the 16" rim, which has a different profile without a lip to hold the tire, and as the result, when the pressure is released from the tire, it can slip off the rim.
This has been reported here at TBN in the past. I am not sure what the solution is. I believe some have filled the tires on tractors with the questionable rim profile without problems, while others have had the tires pop off the rims on their own, when the tractor was jacked off the ground and the tire was just hanging the air as the air pressure was released.
A search might turn up the specific thread that I am thinking of...as might a search of rim profiles for various tractor wheel sizes.
As far as the need for a tube in the tire when liquid filling, it is my impression, after reading a lot on that subject here at TBN, that the need is more of a "rural legend" than a practical concern. This is mostly because for the rim to rust out you need oxygen, and what little oxygen that is in the tire with the liquid is soon depleted, so not much rusting out would normally happen.
Happy Holidays Everyone!
