Filling a Hundred Holes (6-feet across, 4-feet deep)
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #1
60047
Bronze Member
Still searching
My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
What type of equipment is usually used to fill holes left when removing trees? Should I rent a dozer? Or is an excavator more efficient at this task? If an excavator, is a Bobcat E-85 (20k pound machine; 36-inch bucket) big enough to get through that many holes in an 8-hour rental period?
Or should I just truck in some fill dirt and rent a backhoe?
I have a few hundred feet of trenching that needs to be done, so there is material from that. I also need to create a fire break around the wetlands for a controlled burned, so that is another source of material.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #4
Are you digging the ditches and leaving them open? Trying to scrap dirt off the surface is a pain. Digging a big hole or trucking in fill would be better. But filling 100 holes that big would take a lot of dirt. Digging on site is the only reasonably cost effective option.
Yes, the ditches will be open to drain standing water from higher ground.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #6
An 85 excavator will dig a big hole in a hurry but it can’t move dirt any distance. If the terrain is suitable digging a hole and putting the dirt on a dump truck would be fastest. If not you’ll want something with a good sized front bucket. This hole is probably 15 minutes work with an 80. It looks like attachments still aren’t working. View attachment 689994
I assume I can move the dirt with the tractor's FEL. The distance between the hole/dirt pile and various holes is at most 500 feet.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #8
Are all the holes as big as the title says? They must have been transplanting 1’ diameter trees.
About half of them are that big. I would guess they were 8'-12' at the time (blue spruces). Most of the trees are 30' now. Maybe taller.
KOMATSU PC150-5 EXCAVATOR (A51246)
KOMATSU PC150-5...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
