George2615
Super Member
Finally got around to filling my rear tires. I put 39 gallons of -20 degree windshield washer fluid in each. At 7 lbs per gallon that added about 546 lbs. more ballast. I filled each tire until fluid came out with the stem in the 11 O'clock position. That should be 75-80 percent. The tire ballast fill charts for my size tires say 38 gallons per but I put in 39.
One word of caution for those that plan on filling your own tires. If you use the Harbor Freight utility pump be prepared to spend most of the day filling them. I bought the HF utility pump (the bigger of the 2 they offer) which is supposed to be self priming and have an output of up to 300 GPH. DON'T BELIEVE IT. The pump did not self prime and it took me 7 hours total to put 39 gallons in each tire. My rims have metal valve stems with the removable core and housing which allows use of the largest of 3 fittings on the air / water fill valve.
