fill the crankcase via the filter hole?
   / fill the crankcase via the filter hole? #1
bilrus61
Platinum Member
kubota 4200
Ok I'm disabled and its not all that easy for me to take off the side panel (around the loader) on my Kubota L5040 to get to the fill plug. However after I've drained the oil and removed the oil filter there is a nice hole there where it would be much easier for me to fill the crankcase with a funnel and tube through filter hole. I can't see any issue with doing that...Fill it up till its right on the dipstick...screw on new filer....run a bit.......check oil level and go. Any issues with doing that other than that I might need to top off the oil level and would have to do that with the fill plug in the end anyhow?
   / fill the crankcase via the filter hole? #2
I am disabled too and that is what the dealer recommended. I have never tried it as I have my wife or son help me and it sure makes it easier. Of course my wife may have a different view of the process.:laughing:
   / fill the crankcase via the filter hole? #3
Are you talking about trying to force oil through the same hole the oil coming out of the filter would follow on the way to the main bearings?
If so, it would probably work, but a concern would be that it will take a long time. Remember the pump is pushing it at 30-50 psi to get it past the bearings.
I would think it a better solution to have a "trap door" put in place on the side panel so you can just open it up and access the fill port directly. It could be simple as a rough cut opening or elaborate with hinges, finished edges and a latch.
   / fill the crankcase via the filter hole? #4
Once you know the capacity of your tractor you should be able to put the proper amount of oil in the first time. BUT still Check after running to fill the filter. If the oil goes in, I see no problem doing it that way.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
NPK GH15 HYDRAULIC HAMMER (A53843)
NPK GH15 HYDRAULIC...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
