figure this one out
   / figure this one out #1
pagliaccio matto
new mexico
pt-2425
My pt 2425 won't move. It is a new machine I purchased last November. It now has 400 hrs. and has been running very well. All the other hydraulics work but the wheels won't turn. I checked at the side port and oil does come out when I turn over the engine. I also checked the pressure at this port. It was about 80 or 90psi. I think it should be more like 300psi. I did not find any obstuctions in the hoses or fittings between the pump and the pedals. It is as if the tram pump circuit is working, but just barely (not much pressure). It gave out on a steep incline with no way to brake. I was very lucky to have stoped it with the bucket. The lack of brakes in this situation is a very serious design flaw. I use this machine commercially and it is costing me alot when it breaks down. Does anybody know what might be causing this and how I can fix it? Any help would be VERY greatly appreciated.
   / figure this one out #2
My1850 did the same thing... It was a clogged oil filter... But it went slowly so I am not sure it applies...
I will replace the filter this morning and see if it works.
I changed the filter and can see no difference. The pressure at the port is still 80 to 90psi and it still wont move. I'm starting to worry that the problem is with the pump itself. I just replaced a defective pump 200 hrs ago. The last pump failure caused the tractor to become stuck in forward drive (also a very dangerous situation). Although I am happy with the performance of the pt, both events have cost my business alot of money. I have had several other problems with the machine all of which have been resolved. I am begining to wonder about power trac's quality controll on their pumps.
   / figure this one out #5
Does your machine have a hydroback cable or does it use a hydraulic valve on the treadle?
It could be something as simple as a linkage problem -- or it could be the pump, as you fear.
   / figure this one out #7
Have you checked the towing valve to ensure that it is closed? If this valve were opened (or partially opened) to the tow position the sympton you describe might occur.
The low charge pump pressure you report could occur if fluid is not being drawn through the hydraulic filter and into the variable displacement pump in adequate volume. Since you changed the filter I suggest you check for a pinched hose in this circuit.
I assume you have checked the fluid level in the hydraulic reservoir and that it is normal.
   / figure this one out #8
pagliaccio matto said:
kentT
My pt has the valve at the pedal.
I have the up most respect for my fellow PT'ers but I would suggest that you contact Terry at power trac to resolve this matter--- as NJ Bill put it ( do not believe what your owners manual states with regards to --hydraulic flow, part#'s etc.... ) They ( power Trac ) have a serious problem with keeping on top of things regarding updating the manuals for current models. My PT180, Bob999's or KentT's power trac will have a completely different setup than what you have, ( trust me !!!). Power Tracs toll free number
is 1-800- The Yard
Thanks to all for the help. I checked the tow valve and it was closed. I spoke with Terry on Friday. I called him immediately after it happened and he walked me through some diagnostics. First we checked the hoses between the pump and the pedal for flow and debris and found everything to be o.k. Next, Terry asked me to get a pressure gauge to check the pressure at the side port. It took a couple of hours to find a gauge and come back and chek the pressure. Unfortunately, by that time (4:00 e.s.t.) the Power Trac offices were deserted. Terry did not give me any insight as to what the problem might be. I hoped that you guys on the forum might be able to give me some answers and that maybe there was a chance I could have it fixed by Monday. I have a feeling that I will be spending most of Monday removing the pump and sending it to Power Trac again (at my expense). Has anyone else had to replace a pump?
   / figure this one out #10
I'm sorry to hear about your problems, BUT, before you start pulling apart the pump contact terry and discuss the options first!!!. Terry is a very smart guy ( he knows the PT's inside and out ) and he might be able to work something out.... considering you have only owned the 2425 for 1 +/- years. If the rest of us were PT engineers... Terry would be out of a job... and I don't see that happening any time soon!!:D
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
