kspring61
OK, So I have typical symptoms of a fuel issue with one exception. First the symptoms
Tractor bogs down when under a load, going up a hill and/or brush hogging, to the point it will die if I keep pressing it. Even a sharp turn (guessing steering pump load) will bog down the rpm's when brush hogging.
When it starts doing this, if I turn off the PTO and set the throttle to idle, the rpm's fluctuate from 700-1000 rpms for a minute or so and then smooths out at regular idle. I can then make another couple passes brsuh hogging before it starts again.
I have already replaced the fuel filter and air filter.
Here is the exception: When I first start it in the morning and take it out the tractor runs fine, these symptoms don't start showing up for at least 30-45 minutes after running the tractor.
So given this I have ruled out bad fuel
Not sure about a partial plug of the tank because why wouldn't it do this from the get go. It sounds heat related.
One more thing, when it did it this morning I loosened the fuel cap to see if maybe it was vapor locking, that didn't seem to help.
Anything anyone can think of that would cause this to happen after running the tractor for that much time before happening?
This is driving me crazy trying to find this issue
