Mowing field mowing
   / field mowing #1
petroskie
:DIm new to this site and sure this subject has been beaten to death but here we go anyway. for the last year i have been using my quad and a DR pull behind mower to mow neibors fields on our chunk of property. I average 1 acre and hour and it leaves a clean field. we started a family buisness and my department will doing field mowing and rural site clean up and herbicide chemical spray for noxious weeds. my question is what should i charge for the mowing? $100 an acre, $40 an hour, or what. thanks for anyhelp.:D
   / field mowing #2
I suggest you "back into the answer".
Figure in your travel, load, unload, meet and greet, get paid and leave times.
Can you DO 2 jobs a day ? can you do 3 ?
It might turn out that your minimum job size (with those overhead times) is 1/2 day.
You need 1/2 day's pay, plus out of pocket and equipment expenses.
I like FarmWithJunk's formula for field work.
Width in inches (minus overlap) times speed in MPH divided by a hundred equals acres per hour.
Make allowances for turnaround, corners, etc. It is close enough for rule of thumb.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
UNUSED KIVEL MINI SKID STEER PALLET FORKS (A51244)
UNUSED KIVEL MINI...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
Genie GTH-644 (A50490)
New Farm-bilt 6 Lug Running Gear (A50774)
New Farm-bilt 6...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
