Disc Harrow Field cultivator
   / Field cultivator #1
marcin
Bronze Member
Texas
john deere 5205, 1968 john deere 5020
Hi there, just wondering what make, model, size of a field cultivator you would recommend to use with a Deere 5020 tractor (approx 140hp). I have a Deere twa disc plow that I use for first pass or two but am looking for something to use afterwards to smooth the field further prior to planting. I am looking for a used cultivator and am wondering what I should be expecting to spend. Thank you.
   / Field cultivator #2
Pull type I would think 15 - 18 ft depending on soil type, hills, etc. Fully mounted 20 - 24 ft should work fine.
We used to pull 18 1/2 ft fully mounted with 85 HP and neighbor pulled 15 ft pull type with JD 4240 both with duals.
   / Field cultivator
15-18ft does not seem like much, this is a 15 000b tractor. I currently pull a 14 ft disc with it in 6th gear. I do not have duals, however. I was hoping more 22-24'. Any thoughts?
How much more do dual wheels help?
   / Field cultivator #4
I think soil conditions and how deep you run it are gonna play big roles.
Second, just what are you calling a cultivator? Used to be simply an implement with nothing but cultivator points on spring shanks.
things have kinda evolved. What is now called a cultivator......may have a disc gang on the front, cultivator points/shanks in the middle, possibly a spike or chain harrow in the back, and maybe followed by a cultipacker or rolling baskets. Lots of different combos and designs that that are still technically called a "cultivator"
The neighbor that farms in this area, just got a soil-perpetrator / soil finisher to go over the fields this year before planting as he ripped them with a subsoiler last year and they were pretty rough. The local deere dealer just took it in on trade. It was a 24' model and according to spec his ~140 HP 7230 4wd w/rear duals was gonna be too small. Which it is listed at just a tad less drawbar pull than your 5020. Dealer agreed to let him try it first to see if he could pull it. It worked well but certainly wouldnt want any more back there. I think it was called a turbo-till or something like that. IIRC, it had two gangs of wavy flat discs, with very little angle to the gangs (vertical tillage), then a rolling spike harrow, followed by a rolling basket/reel.
Perhaps you have a dealer nearby that would let you try a 20 or 24' of whatever "cultivator" or "finisher" you want and if it works...you're good, and if not....get a smaller one?
   / Field cultivator #6
Two biggest differences I noticed with duals Vs without duals is the ride comfort and fewer tire tracks / impressions in the fields when we were done. Neighbor ran a White 2-105 with out duals and struggled to pull an 18 1/2 field cultivator. He had 20.8 x 38 tires filled with "liquid lead" so he had to be in the 15,000 lbs range. You could see every tire track in his fields.
We had a White 2-85 with 18.4 x 38 filled with fluid and duals. With out the duals in soft peat ground (not wet & muddy)we were spinning the tires with duals in the same ground it never slipped a wheel. Ran this across the scale with out the duals and was right at 13,500 lbs.
   / Field cultivator
Thank you for your input thus far. We have mostly light clay soils. I use an 11 shank chisel plow (IH 45) to plow deeply, and follow with the TWA disc plow to smooth things up. I was hoping to use the cultivator to mostly prepare the seedbed one last time before planting. I am not interested in purchasing a new unit, I want to stay away from the trend of spending everything you make on new equipment. What older brand would you recommend? It seems that Krause used to be a popular brand. I have noticed that the rear wheels slip a lot with the chisel plow all the way down - do you recommend I invest in duals? That would mean purchasing hubs, rims and tires - this may be quite costly. Thanks again.
   / Field cultivator #9
Do you have the option for band type duals? These don't require hubs but will not allow with row crop use and can also fill with mud between the tires since the gap between the tires is usually only a few inches. You would ahve to check to see if these are an option for the 5020.
Is there anyone in your area running duals taht you can talk with to see how much difference they make in your soil type?
We had JD field cultivator. Major wear component to check is the spring tine pivot point. If you can wiggle the shank side to side the pivot is worn and these can be an expense to replace.
   / Field cultivator
This is my current situation on the tractor. I think this will require hubs and rims. Most people I see run duals here on their tillage tractors.
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A42742)
2023 Caterpillar...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
Kubota RTV900 4x4 Utility Cart (A44572)
Kubota RTV900 4x4...
2023 Sany SY95C Excavator (A42203)
2023 Sany SY95C...
2025 JMR 72in Grapple Tractor Attachment (A44571)
2025 JMR 72in...
2020 Nissan Rogue SUV (A42744)
2020 Nissan Rogue...
