Field and Road Roller in the works
   / Field and Road Roller in the works #1
Darryle
Weatherford, Texas
John Deere
I have several places in the pasture that hold water because of compaction, the problem has existed for as long as anyone can remember. The issue is that the fields are rutted up, rough and hard to maintain. There is a substantial amount of native grasses for grazing and about 15 acres of coastal bermuda that will become our hay and wintering grazing pasture.
I have subsoiled almost the entire 31 acres, some twice since I couldn't get the penetration I wanted on the first pass. I am also in the first stages of designing(trying to figure out what shape and how many spikes I will need for maximum penetration) and parts gathering for a rolling spike aerator. That will be a seperate thread.
I want to make this place as no till as possible while maintaining healthy soils and grasses. The aerator will also have an electric broadcast spreader because I want to sow wildflowers in the spring and fall since we just purchased the first two 7 frame Flow Hives, with plans to add several more.
I wanted a field roller that could do double duty as a compactor for the ranch road. The tank I purchased is approximately 54" long and 44" in diameter. I have calculated it out and I think it is 500/525 gallons. There is no plate on it, I can see where it was though. It is heavy enough that my little 3032e struggled to pick it up to load on the trailer, in fact it became a game of walking it on the trailer and off again when I got it home. I purchased the 2" cold rolled bar stock for the axle, 3" x 3" 1/4" wall square tubing for the frame and tongue and 2 2" pillow block bearings. I am going to fill it with sand versus water for the additional weight. If I calculated the volume right, that puts the ballast at approximately 6200lbs.
Pic of the unmolested tank
More to come.
   / Field and Road Roller in the works #3
Looks like a used propane tank. There are probably residual propane fumes in there. Are you going to drill a hole for the axle?
   / Field and Road Roller in the works #5
Fill that thing full of water to push all fumes out before doing anything with it! Doesn't take much to go wrong. If you have some high temperature hose that you could get exhaust from a gas engine into it would also work. Just need to displace the residual fumes. Great idea and have seen 100 gal tanks used as rollers.
It was a propane tank, the valves had been removed prior to me getting it. The guy I bought it from had it for close to 5 yrs and it was open when he got it. There is no residual smell of mercaptan.
I have a carbide hole saw that I will use to make the holes for the axle.
   / Field and Road Roller in the works #7
Exhaust gas is also explosive.
   / Field and Road Roller in the works #9
It was a propane tank, the valves had been removed prior to me getting it. The guy I bought it from had it for close to 5 yrs and it was open when he got it. There is no residual smell of mercaptan. I have a carbide hole saw that I will use to make the holes for the axle.
While welding in the oil patch, first thing we were taught was to not weld on any old tank. Enough flammable materials would leach out of the steel to make it explosive no matter how many years ago it was last used.. As others have suggested, it needs to be filled with something like Co2 or H2O to keep it from gathering whatever flammable materials and making it unsafe to work on. Personally I'd just fill it with water.
   / Field and Road Roller in the works #10
Have cut a few propane tanks, always fill with water. Leave the water in. Angle grinder with a thin blade, plan your cuts.
2015 John Deere 310SL (A47384)
2015 John Deere...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
