few questions about the L3400
   / few questions about the L3400 #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
Awaiting a call from the dealer letting me know my tractor has arrived. In the mean time, I am doing some research and need to tap the expertise of the TBN'ers..
from the kubota website:
"The L4400 features a powerful and versatile hydraulic independent rear PTO. For increased productivity, the L4400 PTO can be engaged and disengaged without stopping the tractor. The L2800 and L3400 HST models, as well as the L3400 gear-drive model, feature a live, continuous running rear PTO."
So what exactly is the difference between a "hydraulic independant" and "live-continuous" pto? what are the advantages/disadvantages to each? As an operator, what is the proper way to engage/disengage the live type?
Also from the kubota website:
"Mechanical cruise control is a standard feature on L2800 and L3400 HST models. For an easy way to keep your working speed constant regardless of terrain, simply set the infinite mechanical cruise control lever to your desired speed. Changing your speed is as simple as operating a single lever."
Back in the 80's, I used to run an International 1466 combine with hydro, no pedal but there was a stick next to the right hand arm rest and to move forward i would push the stick slowly forward until the desired speed was reached. To reverse, I would pull the stick back to the N position, slide it slightly to the right and pull back. so is the mechanical cc on the 3400's work this way? Does it only work for forward movement? Do those of you that have this feature use it more then the foot pedal? Is it convenient or hardly used?
One final question, if I wanted to add a grapple/remote to the loader, what options do I have to make this happen on the 3400? What is the realistic cost of doing this and how hard is to do for someone with limited hydraulic's expericence? Somewhere along the way I remember a dealer (can't remember which manufacturer dealer told me it would only be a few hundred $$ where another one told me it would cost a couple grand).
cheers,
bigballer
   / few questions about the L3400 #2
The hydraulic PTO can be engaged without clutching.
The Live PTO on the L2800HST and either L3400 model must use a clutch. When you clutch you stop too.
The cruise on the L2800/3400HST is simply a mechanical lever that locks the HST pedal into place. It works only in forward.
I know nothing about the grapple. I added a rear remote to my L3400HST. There is a kit from Kubota that bolts to the ROPS.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
Chevrolet 2500 Flat bed (A56438)
Chevrolet 2500...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
