Few Hydraulic system questions
   / Few Hydraulic system questions #1
wkheathjr
Bronze Member
Seven Springs, NC
80's Massey Ferguson 240
1) I read that if you keep pump and tank very close, it will help keep fluid temperature down and prolong the life of system. I am curious if having a very long hose will cause temperature to rise? If so, would it help to have a little bigger tank for that? Or what is best solution?
2) How do you determine the size of tank and GPM based on what you are using. Suppose you have two gear pumps and four cylinder in your system, how do you determine the result to know what type of PSI your system need at RPM, and how much HP is required from your gas motor for the system?
3) Suppose you want to use a gear pump to move your vehicle at say 10-15MPH, can it be done (belt-driven system similar as kart)? And how do you know how much RPM is needed to get that speed?
Thanks!
-Ken
   / Few Hydraulic system questions #2
You have to start from somewhere. It takes a certain amount of HP to drive a pump or pumps, in order to pump fluid. The tank size has slowly been reduced down to one gal in the tank for each gal pumped. Theoretically, it should be about 3 to 5 gal tank for each gal pumped, in order to give off some of the heat, and maybe let bubbles dissolve, etc. The pressure is determined by the manufacture of the pump, but is not developed until the fluid sees some restriction in the flow path, such as cylinders, motors, relief valves. If you are using a hydraulic motor, and pulley/belt combination, you have to figure out the torque and rpm available to turn a wheel and how fast, and that will depend on the size of the wheel, and how much weight is involved, and so on and so on. We can give you some do's and don'ts, but you will have to build it your self, or buy it off the shelf when you figure out what all the parts will cost you.
Or you can start backward from how fast do you want the machine to run, and back things from there. There is a lot of engineering know how involved to make things work in a logical manner. A lot of people are always modifying things, and sometimes they succeed, and a good many fail. So, if you do your homework, you might be one of those that succeed.
Maintaining the correct temperature, is just one of the factors you will have to figure, like should I add a hyd cooler, use larger hose, etc
Hmm.. well, let me rephrase my question.
What I mean is that suppose I know I am planning on using four 3" bore x 16" stroke cylinder, one 4" bore x 24" stroke cylinder, and one high pressure gear pump with .517 disp cu in. using 4.0 GPM @ 1800/8.0 GPM @ 3600 RPM.
With given information, how do I know what oil capacity will I need for given system and GPM of stage 2 pump will be needed? Then I will be able to locate the HP motor needs to be based on required GPM of stage 2 pump.
Hope this is more clear??
I did ask someone before and his short answer was "2 stage pump will do" but problem is that what GPM of pump? What size of oil reservior and how much gallon of fluid is needed? I want to know how did you find the answer so if I add or deduct the design then I can do it on my own without having to ask and ask.
Many thanks!
-Ken
   / Few Hydraulic system questions #4
A pump rated 10 GPM at 3600 RPM and 2500 PSI, requires about 17.5 hp to drive it IIRC but please correct me if I am mistaken!
A quick Google for hydraulic calculators and a little perusing of the results should give you all the info you need.
Reservoir size traditionally has been at least 3 times the pump capacity and should contain additional space equal to at least 10% of its fluid capacity, so for an 8 GMP pump that means at least a 26.4 gallon capacity tank filled with 24 gallons of fluid. It all really depends on the usage however and if you are planning on light duty, you could try a smaller tank and less oil. Remember though, you need adequate volume to allow the fluid to rest between work cycles for heat dissipation, contaminant settling, and deaeration.
   / Few Hydraulic system questions #5
wkheathjr ,
In order to do anything, you need a final goal as to what you expect to achieve. For instance, I want to carry XXXX load at 10 MPH. From this point, you will have to decide on hydraulic drive, gear transmission, belt and pulley, etc. For more instance, how large a tire do I need?What rpm does it have to turn to give me 10 MPH. How much weight will I have to move to achieve this speed, including driver. Will the machine be doing other things other than just driving around. Is this a work machine? What work. How many functions? You need to fill out a work sheet on all aspects of your project. You will have to follow a logical order.
Anybody can throw things together and maybe it will work to some degree, but logical thinking will usually provide good results.
There are a lot of ifs, and what ifs you are asking. We can probably start you off in a general direction, and you can ask questions along the way. There are a lot of smart people on here, but unfortunately I am not one of them.
Just curious, are you trying to make a hydraulic go cart?
Sort of. I was thinking of making a utility vehicle similar as gator or mule using hydraulic system that would use gear pump to move it and add a dumping bed that probably can hold 600-1000lbs capacity depending on what it can do. And possible a reconnect hydraulic coupling that you can connect a towable backhoe or towable log splitter to it. Anytime I am ready to use small backhoe or log splitter, I can hook the trailer to it and connect the hydraulic system then open that line to it. The towable backhoe would be from ubuilditplans.com
I really don't know if this would work but I am trying to do homework first and trying to understand hydraulic system.
Mace,
How did you get the answer of 10GPM @ 3600RPM with 2,500 PSI?? That is what I was asking. A guy can tell me what I need but it doesn't help me because it doesn't tell me how you found the answer. In the future if I want to design something new then I will end up coming back to ask and ask. Better to know how to find an answer now so I don't have to ask again in the future.
JJ,
Yeah I found the link on Fri but this is what I have: surpluscenter hydraulic
I think the issue I am having is that when there are few motors and few cylinders all together in one system, I am more worried about whether I am having correct GPM stage pump and oil reservoir tank than if I have right motor or cylinder for the job. The calculator is good but where does it give result when you input all the motors and cylinders then get the right GPM pump result?
That is where I am afraid that I might end up buying wrong stage pump and wrong size of tank then see my system fail because of heat from having too much or not having enough power to meet the demand that its working slowly.
Or was I supposed to know the exactly result from each motor/cylinder and then do the add-up and use the result to determine what stage pump I need and how much fluid?
   / Few Hydraulic system questions #10
The hydraulic pressure will determine the force in lbs/tons. The GPM will determine how fast the cylinders will extend or retract. If you have enough engine force to turn a pump, then you will develop potential force, because with no lever activated, the fluid is going through a loop from pump to tank, with no or very little pressure. It doesn't take a large pump to move cylinders. A 2 GPM pump at 1500 psi will work those cylinders, and the hyd calculators will help you to figure all that out, in force generated, and speed of operation. A Larger pump in psi and GPM, will operate larger cylinders and motors. With all that , you need the correct valve, filters, and reservoir.
Why not use the hydrostatic transmission from, or modify the garden tractor with a large enough motor to run the transmission, and any aux pump for a log splitter, etc. The tractor motor will have two belts , one to drive the hydro, and the other pulley cold drive the aux pump. Using the tractor, you don't have to engineer a lot of stuff.
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2014 Glasstream 360 SCX (A51694)
2014 Glasstream...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
