Ferris IS 2100Z Oil change
   / Ferris IS 2100Z Oil change #1
donnyl
Chatsworth GA
Kubota B7500
My 2100 has almost 10 hours on it and wondering what kind of oil do I need to put in it. It has the kawasaki FX801V. I have asked 2 dealers and got 2 answers. One said 10w30 and one said 20w50 kawasaki oil. How many hours on your machine and which oil do you use?
   / Ferris IS 2100Z Oil change #2
I read somewhere that Kawasaki changed their oil recommendation to 20W-50. Didn't you get an owners manual with your IS2100? What does it say? Have you tried going to Kawasaki's website to see what they recommend for that motor?
My Manuel does say 20w50. Just read it. I was wondering if anyone was using something different?
   / Ferris IS 2100Z Oil change #4
Why go against the manual? Is 20w-50 hard to get or what?
Sounds like your Manuel read the manual.
I'm not wanting to go against the manual , I just wanted to know if anyone uses a different brand of oil in the 20w50. You can buy 20w50 in Castrol, Penzoil, Moble, Kawasaki. Is there a difference in brands?
   / Ferris IS 2100Z Oil change #6
No, there's not really any difference in brands as long as you stay with a name brand. Write down the specs listed in the manual for the oil. I.e., not only the weight but the service classification (such as "SF, SG, SH, SJ or higher"), and buy a name brand oil that meets those specs, and you'll be good. Then at 50 hours or 100 hours, I'd recommend changing to a synthetic oil that meets the specs in your manual. But that's just a personal thing with me. So long as you use a good brand of oil (whether dino or synthetic) that meets the specs in your manual, you'll be fine.
And when you replace the oil drain plug, don't go all gorilla on it. Some people have been ham-fisted and stripped the threads by over tightening. You want it snug, but not too much. If you have a torque wrench, tighten it to the torque specs in your owners manual. Same thing with the oil filter. You want to spin it on by hand and tighten it hand tight, and maybe another quarter of a turn with a filter wrench. But you don't want to tighten it too much. Just follow the manual.
   / Ferris IS 2100Z Oil change #7
I agree, stay with the manual. Now I am in the same spot, I have the new Hustler Fastrac SD with the Honda engine. The Manual of Hustler said change the oil at 8 hr and the Honda manual said 20 hr. Now I will follow the Honda, since they have the 3 yr warranty. I did call the dealer he suggests the Castrol regular 10w-30, Honda says any 10w-30 but if I do go full synthetic to use 5w-30. Now which is better for -25c ~ + 44c. I have run into a few issues on the filter, Which brand to use? Honda said that if I do not use a pacific filter, I will void the warranty. Unfortunately, no dealer within 3 hours of me carries the filter, I am confused.
   / Ferris IS 2100Z Oil change #8
I used Mobil 1 full synthetic in 20W50 for my first oil change with spec to SL rating which is what the manual specified, weight and rating only-it didn't spec to use synthetic but the dealer did say to only use full synthetic.
Now I have started using Shell Rotella T6 10W-40 in everything I own so I don't have to buy 10 different grades of oil. It is rated for diesel and gasoline engines.
2018 GENIE GS3246 (A45046)
2018 GENIE GS3246...
2017 John Deere 652R 52in Stand-On Mower (A42744)
2017 John Deere...
2012 WESTERN STAR  4900 TRI DRIVE 60 TON CRANE TRUCK (A45333)
2012 WESTERN STAR...
2011 LONE STAR UTILITY TRAILER (A45333)
2011 LONE STAR...
Transmission-Allison 9823 (A45333)
Transmission-Alliso...
2016 Nissan Titan 4x4 Crew Cab Pickup Truck (A42744)
2016 Nissan Titan...
