Oil & Fuel Fergy 135 Fuel tank mounting
   / Fergy 135 Fuel tank mounting #1
Tarenja
Warrnambool, Victoria, Australia
Ferguson 35 (petrol) 135 (diesel)
Hi guys.
I have a Fergy 135 diesel that we are tidying up to send to Papua New Guinea as part of a humanitarian aid project.
The tractor has done a lot of work but seems ok mechanical albeit there are a lot of things that have never been fixed properly or have "emergency" repairs only.
The problem I have at the moment is the fuel tank is "floating"; it's not mounted in any way.
Can anyone tell me, or better still send me an image of, how it mounts please.
Thanks in anticipation
Tony
   / Fergy 135 Fuel tank mounting #2
G'day Tony and :welcome: good to see someone on here just down the road from me (so to speak).
You will have to remove the tank more than likely the strap under the tank that the mounting bolts go through are broken off the tank easy job to solder them back on or if it is out of your scope then a good radiator repair place should be able to do it just make sure when you bolt it back down you have got some rubber spacers between fuel tank strap and mounting bracket, we make them up out of some old rubber belting about 1/4" thick and 1"1/2 " square
Jon
2006 Acura RL Sedan (A51694)
2006 Acura RL...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2025 AGT SDA-140W (A50123)
2025 AGT SDA-140W...
