Ferguson hydraulic problem
/ Ferguson hydraulic problem #1
smurl
bon aqua , tenn
52 ferguson
Using my 52 to20 spreading gravel the other day and box blade went up and won't go down. Always has worked fine for bushogging and whatever I need. Hydro oil got some water in it. Its a yellow color so I unscrewed drain plug. Almost out the plug shot out in bucket like a bullet. The box blade was up but when drain plug shot out box blade dropped. Oil definetly needs changing but is there anything else. Also noticed up down lever felt like no pressure on it. I use tractor a lot and hope there's an easy fix
/ Ferguson hydraulic problem #2
Down lever only releases fluid to reservoir/tank.
Your tank should not have pressure in it.
There is a vent somewhere just for that purpose.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A59230)
2012 Mack CXU613...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
Case Titan 3530 (A61307)
Case Titan 3530...
