fencing
   / fencing #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well.. it's finally come down to it. i've been putting it off.. but can't any more. The pasture down the road that I've been renovating has poor fence on it. The rear fence is back in a treeline about 20-30' in and is on the ground and has been that way since i bought the property. The front i was leaving unfenced so i could get down and mow / maintain it.. Finally had to throw up a t-post / 3 strand barb wire fence a few years ago to keep all the atv riders off the property.. they were rutting it up bad and making me go theu shear pins like candy. Pasture has pretty good grass on it now, but I wasn't planning on putting animals on it for a few more years as I got other irons inthe fire ( financially ) and can't put a barn/well/power there for a couple more years. Well.. with fl's hay shortage and drought continuing,, I finally decided I'm gonna have to move some animals out there next month. My main pasture has had it.. it's going bare.. and getting drier by the day, and no hay in site for at least a couple months.
I gotta get to the back and put up a fence.. preferably 2x4 wire on t post with wood corners and H braces every 100'. If the trees are too dense to get a decent looking woven wire fence in.. i may break down and go 5 strand barb wire.. though If it can be 'chainsawed to make the woven fence go.. I got my brand new poulan pro with me.
For the front i also want to go with 2x4 wire.. guess I'll have to pull all those 5' t post and drop in 6' ones for the new fence... Wish I'da put the bigger ones in and not saved a buck each when i did it the first time... oh well... live and learn.
Best part is i conned my best friend into coming over at noon to help me. By then I oughta have my tools loaded ont he trailer and been by TSC and lowes to get my fencing supplies.
Gonna be a loooong day.
See you guys!
Soundguy
   / fencing #2
I'm right there with you brother. My bride and I are putting up another 800+ foot internal fence, with two gates, this weekend. Ran into some very solid rock on the third wooden post (8' of recycled power line pole). Went to HF for their 77 lb. Breaker Hammer on sale for $399, down from $499.
See posting #15 http://www.tractorbynet.com/forums/build-yourself/89011-anyone-have-harbor-freight-coupon-2.html
If anyone is interested, will give you a performance report on the hammer.
In FL, bet you don't run into rocks, or do you?
   / fencing #3
Soundguy
Couple of questions for you, don't take them the wrong way, I'm trying to learn. Different parts of the country have different terms and needs...
What is 2x4 wire?
Why do you need braces every 100'? We used to pull a mile and a half of 4 strand barb wire to the corners, don't see what extra braces on a post would do in the middle of a run, do you tie off the wires every 100 feet? We only braced (I imagine the same type of thing you are calling an H-brace) at the ends of the fence, corners or on each side of a gate, because that's what held the tension.
Again, just wondering, if it's commonly done, there's surely a reason.
   / fencing #4
I bought the exact HF 77# jack hammer just for braking through the rock to set poles. It works very well, although you can not get very deep, so I modified it. I bought another bit, cut the end off and welded it to the spade bit to extend it another foot (spade bit works better at breaking the rocks) worked like a charm. It is still no easy task as it will work you to death pulling it out of the hole.
My next mod will be to weld a "cup" on the end of a bit and use it to drive "T" posts.
   / fencing
2x4 wire... horse fence.. has a 2" x 4" weave. Field fence is more like 4x4 or 6x6 ( cattle ).
I like an H brace on 2x4 fence aver hundred or so feet. maybee 200'.. just depends on the fence. Redbrand with heavy top wire and wire weave i can get away with H braces onthe corenere, and a single H brace in t he center on a 525' run.
1.5 miles and nothing but corners? Guess we got different wire than you do.
Locally the biggest roll of gaucho i can even buy is like 80 rods or 1.25 mile.
If I have wire up against a wood post.. i staple it.. if it's against a t-post.. I clip it.. I'm no fence expert.. but I can't imagine a 1.5 mile string of wire unsupported except on corners and having no sag or deflection. I'm afraid my cows would push their heads in and spread the wire..
Soundguy
What is 2x4 wire?
   / fencing
Update:
I got the fence inthe back.. Had to end up going barb wire on t-post with H braces at the corenrs.. was only a 335' run.. so no need for a center brace.. it stretched nice and tight just fine.
Font fence was reconfigured for a 4th strand without much work other than reclipping a couple wire strands.
Soundguy
   / fencing
I could not make a 100% straight path.. figure dthe HT would look kinda buggery not being able to zig zag a bit. Some of the tree's didn't cooperate in the fence line.. (grin)
soundguy
   / fencing #9
We never use any woven wire for anything but keeping rabbits out of gardens...all barb wire for everything, or cattle panels and/or wood fencing in working areas (sorting pens and around working chutes).
Soundguy
Sorry, should have said just steel posts the rest of the run, no additional bracing though, no problem getting the fence to maintain tension over a 1.5 mile run. Most of the wire is old...dating to homestead times. When we have done new fence, it's just 1/4 mile rolls, splice as needed. Cows won't challenge the fence unless they are out of food or water.
   / fencing #10
I have been looking for bits everywhere. Where did you find them? I want to do the same thing, weld a cup for driving t-posts.
UNUSED SDLANCH SDLE18P EXCAVATOR (A54756)
UNUSED SDLANCH...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2008 Ford F-150 Ext. Cab Pickup Truck (A53422)
2008 Ford F-150...
Manac Walking Floor Trailer (A50322)
Manac Walking...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
