Fencing Question
   / Fencing Question #1
jtn
Illinois
New Holland TC45D
I am building a fence around part of my property. It will be three strand barb wire on cedar posts. My property has very few natural trees so I would like to keep as many as possible. Unfortunately one of these trees is right on the corner of my property where I need to locate a post. It is large and nice looking so I would not like to cut it down. Putting the post right next to it would be fine but I could never dig through the roots by hand or with a PHD.
I have considered the following options:
1. Nail the wire to the tree (simple, easy, and cheap)
2. Pounding in a pointed stake or steel post next to the tree (might prove difficult or impossible)
3. Cutting the corner and fencing around the tree (not aesthetically pleasing)
Any advice or other suggestions would be welcome.
JT
   / Fencing Question #2
I think I would try option #2. Driving a steel fence post in on either side of the tree. As close to the tree as possible yet allowing for future tree growth. If you can get them driven in through whatever root base there might be, you could at least form the corner of the fence line, either just in front of or just in back of the tree.. tree being either inside or outside of the fence. Then go back to ceder posts.
You didn't say what kind of a tree it is, (root base) but I think you would stand a better then average chance of getting a couple of metal fence posts in
It might not be the prettiest, but sometimes necessity takes priority. You can always do something creative to blend the metal fence posts in. I think it would look better then having to cut the corner off.
   / Fencing Question #3
jtn, Depending on what type of tree it is and what the other property owners I would nail to it everytime. They make fencing very easy. Fantastic to stretch too and from. Drawbacks, don't completely wrap around it or chance of dying increases. Don't nail wire to hickories due to some kind of chem. reaction that eats up the wire. If it is a line tree and it dies, your fault nature's fault nobodies fault, it will be blamed on the wire. I would probably nail to it, no more damage than digging into the roots. But it would depend on the tree type.
   / Fencing Question #4
Also, wondering what kind of tree you have at the corner?
Depending, I would incorporate the tree into the fence and not place a post next to it, as the tree will grow in diameter and push against the post (of course, that will take a few years depending on the species of tree). I wouldn't wrap anything around the tree for the same reason - that the girth of the tree will increase.
SO what I would do, is drill three holes through the tree(either straight through at 45 degrees to cut the corner or two holes that meet in the middle. Then run the wire through the holes. These holes may grow shut at the bark over time, but they will not change relative position up or down, nor with respect to the center of the tree. This should not hurt the tree.
Usually trees on property lines, and especially at corners of properties, are also the property of the neighbors. What do they say?
Good luck with your fence.
   / Fencing Question #5
They make what they call a mule anchor. It goes in the at an angle and holds your corner post in. That's what I'd use for that area.
   / Fencing Question #6
Put a post beside the tree and strap it around the tree. use turnbuckles or some other type of device that will let you make the strap bigger in the future. Nail the fence to the post
   / Fencing Question #7
Morning,
<font color=blue>I am building a fence around part of my property. It will be three strand barb wire on cedar posts.</font color=blue>
If I was your fence contractor talking over the job with you or if we were neighbors and asked my opinion I'd probably offer this suggestion.
I'd stop the fence eight to ten feet from the tree on each side. Then I'd build a gate looking panel that would be attached to the post and tethered at the tree.
Here's the logic involved. One, if you bring the wire up to the tree and don't wrap around the tree you only have staples or nails supporting your fence against the pull. That isn't worth a flip. Two, if you wrap the tree you have just signed it's death warrant. Trees don't like being choked for very long. They'll get mad and die just to express their disgust with your lack of consideration.
The frame can be wood or steel or even aluminum and it doesn't need to swing. I'd tether it to the tree with a loose knot, preferably rope, not wire or cable. Eight to ten feet out you have a fifty to fifty chance of not hitting a major root and your odds aren't that good closer in towards the tree.
Make sure you're using hot dip galvanized staples when attaching the wire to the cedar posts. The chemicals in the cedar love iron for some reason. The will eat it quickly. They take a little longer on galvanealed or electroplated but not much.
If you go to a box store you will pay dearly for hot dipped galvanized anything. So the best source is where the professionals buy because they buy hot dip galvanized products for just a tad more than the lesser quality stuff.
I wouldn't blink about attaching three strands of barb wire to a tree as a line post. I can show you one tree, Hackberry, in Dallas that twenty five to thirty years ago had a chainlink fence put up next to it. I removed that fence, well not all of it. The top rail is cut off on each side of the tree because it's dead in the middle of it, same with the fabric. That's a ton of steel and galvanizing and no visible damage to the health of the tree.
I'm sure you have a system all figured out on working with the barbwire. The stuff is nasty. It's sorta like an ex mother in law. About the time you think you're safe it strikes from your blind side and cuts you to pieces.
I use good leather gloves. I will use a piece of pipe across a wheel barrow as an axle for unrolling it when I'm doing short sections. For longer sections I use a piece of steel rod or pipe stuck in a stake pocket on the truck with a plow disc sitting below the roll of wire. This allows it to spin free while driving down the line.
I will usually do the top line first. That way the other lines aren't as likely to get entangled with the first ones. I have learned to be very careful when cinching it down after wrapping a post on a corner or end. I will usually hand wrap the first couple of coils and then use the serrated edges of the pliers to wrap a couple of more. I don't use the serrated edges of the pliers for the final tightening on those hand wrapped coils. And I do my doggonedest not to knick the horizontal wire. A knick can hurt you two ways. First it might weaken the wire to the point where it breaks and then decides to get even with anything close for having been stretched. It opens the door for quick rusting and then it breaks later. Usually when it's too cold or wet but has to be done anyway.
   / Fencing Question #8
For ease, I would go for #1 and make the tree the corner post. Except rather than nails, I would use screw in eye bolts. A lot more secure and sturdy than nails. And you don't have to wrap the wire around the tree.
For more effort, I would set 2 pipe posts each side of and near the tree. Then I would weld pipe cross bracing between the 2 posts and then weld some pipe "wings" that would reach almost to the tree to close the gap. That would also provide a very study end to your fence. Of course, now we are talking about a lot more work. /w3tcompact/icons/smile.gif
   / Fencing Question #9
<font color=blue>Cutting the corner and fencing around the tree (not aesthetically pleasing)</font color=blue>
Why not? If the tree is nice looking and right in the corner, I'd fence around it and and make the corner look nice with a few shrubs and some bark mulch. It will look better than barbed wire nailed to a tree, in my opinion /w3tcompact/icons/smile.gif
   / Fencing Question #10
My fencing contractor uses trees all the time. Generally he nails a piece of pressure treated wood to the tree and attaches the wire to the wood. This protects the wire from chemical reaction with the tree. Apparently, depending on the species of the tree, this can be a real problem.
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
Super Material Lift MH1000 (A52128)
Super Material...
IH 445 Square Baler (A50515)
IH 445 Square...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
