Fence stretcher/installer
/ Fence stretcher/installer #1
Brad_Blazer
Veteran Member
Caldwell Co. NC
2006 Kama554; 92 Belarus 250AS
When I visited my brother last summer someone had loaned him this fence installer/stretcher. I thought it looked like a good idea so I took some pictures so I could make one.
I was off Thursday and Friday and made good progress on my own.
When it is time to stretch the fence it gets clamped between 2 pieces of angle iron. Here is a detail of one of the clamping levers.
Saturday I pretty much finished it up adding the fence roll carrier. The base is a disk that was a cutout for a manhole on a large tank. It looks a lot like a cultivator disk. There is a hole in the center of the disk for a piece of 1.5" pipe. A pin through the top of the frame secures the top end of the pipe. I also added some feet under the disk so it will stand up to make hookup easier.
Here it is complete. I will still add some small gussets where the horizontal channels are attatched.
Top detail. I welded a stub of the same pipe to the hole in the channel and made a fat pin to drop in. The washer seen on top is welded to the pin.
And here is a picture of the fence clamps in the locked position.
Brad
/ Fence stretcher/installer #3
You did a good job on that. I've been thinking of something similar. Thanks for posting the pictures.
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2025 CATERPILLAR 265 SKID STEER (A65056)
2025 CATERPILLAR...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
2009 BETTER BUILT PH2322DT-E TRAILER (A66091)
2009 BETTER BUILT...
