Fence Project
   / Fence Project #1
Shemp
I'm getting ready to plant some olive trees out on my land. The wildlife around there will eat them up if I don't put up a good fence. My main worry is keeping the deer out. Tractor Supply has some 6 foot high fence. Is this going to be high enough to keep the deer from hopping over and having a feast? Thanks.
Also, what is a good spacing figure to use for fence posts? 6ft, 8ft or more in between fence posts.
   / Fence Project #2
Most high fence deer ranches have 8' plus fences.
   / Fence Project #3
not sure where you live but 6' would be a hop for a big whitetail.
   / Fence Project
****! I'm down in Texas around Columbus. I guess I'll get a bigger fence.
   / Fence Project #5
Down in Rural Living you'll find a couple of threads on deer problems. It's an interesting topic. There are some people here on TBN that have fought the good fight and won. There are others who are enjoying the fight so much that they're not interested so much in winning as they are in, well, fighting the deer.
   / Fence Project #6
Neighbor has a 6' deer fence in 45 degrees outwards. He says the deer will not jump it.
   / Fence Project #7
10' to 12' between posts is common. For your purposes, I think you could get away with 20' and later add T-posts in between if needed. Your stretching posts need to be substantial and anchored well. Is this going to be as much as an acre? How big will your olive orchard be?
   / Fence Project #8
Ditto what jim said about post spacing if you got good corner and brace posts.. you can go 20' on t-post inbetween.
as for deer fence.. to be 100% safe.. go 12'.. 8' will probably deter all but the best jumpers..a nd 6' will keep alotta stuff out... but not a hungry deer if he -really- wants in.
Deer hop a 6' field fence down by my stepfathers place pretty regularly.
soundguy
   / Fence Project
Right now it's probably going to be around 3/4 of an acre with plans to expand as needed. When you say stretching posts I'm guessing something like a 10' 4x4 post concreted into the ground. The T-posts I'm not too sure what you mean there. I was planning on using the tall green posts that I've seen used for wire fences.
   / Fence Project #10
T posts come in various lengths, they look like a T if you look at em from the top or bottom and have the ridges on one side and are driven into the ground.
Probably the most used fence post in existence.
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
