Fell slow to lift
   / Fell slow to lift #1
Tdog50
Ontario
Jinma 224
The fel on my Jinma 224 is slow to lift. When I apply right to the steering it lifts like it would normally but when steering is neutral it is slow. Anyone have this happen? Could it be a cylinder bypassing. Had both steering cylinders rebuilt last fall.
Tdog50
   / Fell slow to lift #2
You might have some crud inside the diverter valve, but I'm not sure if that would cause that exact problem. The valve is above the right foot rest, and it's not hard to take apart.
Something that's a lot easier to check is the hyd fluid level - when mine gets low everything gets a lot slower, but it speeds up intermittently. I'm chasing leaks in gaskets right now, so my level goes up and down daily whenever I pull fittings off. Make sure to check the fluid level with the dipstick unscrewed.
   / Fell slow to lift
Sorry meant to say both lift cylinders rebuilt.Yes got a breakdown of the diverter valve will check that.
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
