FEL Tractor Crane *Proof of Performance*
   / FEL Tractor Crane *Proof of Performance* #1
PhilCase
The Missouri Ozarks
The internet is an interesting social phenomena. Because of the relative detachment most people feel with their posts, what they post tends to be an unfiltered look into their nature, as opposed to in-person conversation where they tend to *audit* their communication for various reasons. As a result, this it makes it relatively easy to figure out, from peoples posts, who's a good go-to resource on future projects, and who you are glad isn't your neighbor.
Special thanks to those members here who made meaningful suggestions on the crane project. Notably Mock1 who noted some of the cable clamps reversed; mbohunter, who pointed out risk-potential with the turnbuckles; and jimgerken who pointed out the potential problems with the plastic coated cables.
The award for most accurate analysis has to go to jlrsn, whose first observation was "overbuilt" which proved to be correct, and his observation that the winch was "something else to go wrong".
Here's the story:
The crane worked great, exactly the right tool for what I needed. I did decide to safety wire the turnbuckles, but it turned out an unnecessary precaution as the turnbuckles performed flawlessly. The RF control on the winch, however, failed to respond while working the 2nd truss. (Harbor freight - go figure.) So I stripped the RF control module off the winch and using two sets of jumper cables and a bungie cord I created my own home-brew winch control system. By connecting like polarities together the winch would extend, and opposites would retract. This actually worked out great.
I put stop blocks on top of the headers ahead of time so I could set the trusses against the blocks and not leave the tractor until I knew the trusses were already on their marks. This went very well, in fact I never had a single truss that required more than a half inch of position adjusting to set. The crane was easily able to lift the trusses, and carrying them over the tops of the ridge posts was quite useful as getting the truss above the building then allowed for easy tractor positioning to get into setting position.
The process after transporting the trusses, then lifting and sitting them, was with the truss was still attached to the crane, to climb the walls and use clamps to clamp the truss ends to the stop blocks (or in some cases posts), then, using scaffolding put in temporary bracing: 2 top-chord, 2 bottom-chord, and 2-diagonals. Then toe-nail the trusses to the headers, detach the crane, and repeat on the next truss.
After getting a stretch of 5 trusses, I'd go back and put in the permanent bracing.
Final analysis, despite the "opinion" of some, this was an effective, efficient, and safe tool allowing me to do a job myself that normally would require a crew of several people.
I haven't had time to build a good presentation, but all raw images are available here. Video of first truss lift test is also available here.
All the best,
Phil
P.S. Final video next week that will feature one more modification, this one dedicated to jlrsn. :)
   / FEL Tractor Crane *Proof of Performance* #2
Awesome every step of the way from planning, building and use of your crane to do the job it was designed for.
   / FEL Tractor Crane *Proof of Performance* #3
PhilCase,
I'm glad it worked out for you. I respect your challenging yourself and believing enough in yourself to go to new frontiers no matter the outpouring of naysayers!! I look forward to your next project!
Have a great day,
Jim
   / FEL Tractor Crane *Proof of Performance* #4
Ok, now that is done, would you please go visit China Phil, get a work visa, and show them how to explain a process to create a good instruction manual if they are going to sell their stuff elsewhere. I could of put up a nuclear fission plant with your type of instructions. Great job on many fronts.
Also, at this point, it may be easy for some to disparage the naysayers but I'd like to believe they had Phil's safety in mind. Unfortunately, as with many posts here, it got to be a shoot out. If we can all remember we are all in this together. There is rarely a true external enemy larger than the one we formulate between our own ears aided by the "ego."
   / FEL Tractor Crane *Proof of Performance* #5
Worked out good.Really sucks that the winch remote failed. But you adapted well.I am sure it made it easier. I know for me it did , I was working alone.
   / FEL Tractor Crane *Proof of Performance* #6
Well Done!!! I'm glad it worked out!!! I would have felt very bad if I hadn't cautioned you on the possibilities and it might have prevented an accident.. Every great invention started out with some trial and error. I also see that you took note of many suggestions for mods. Thanks for sharing, and letting us heckle you to death. :thumbsup:
   / FEL Tractor Crane *Proof of Performance* #7
"PhilCase" Great Job and Presentation !!!
Thank You for sharing your project with such detail.
Rhett
   / FEL Tractor Crane *Proof of Performance* #8
PhilCase,
Job well done. I figured it would work. You probably didn't need any help at all, which was why you built the boom. There will always those that say, don't do it, not safe, or whatever, which is based on their own experiences of failure. So what if one fails, get the heck up and fix it or make it work. Trial and error, hoping the first trial is correct. You did good, and keep up the good work.
   / FEL Tractor Crane *Proof of Performance* #9
Philcase
Congrads, that is going to be a nice building, happy to here it worked so well!! Thanks for the complete story and pictures, they were great.
I stick by what I said early in the other post "I like it"
Mark
   / FEL Tractor Crane *Proof of Performance* #10
Very nice job, Phil!
Now that you've used it quite a bit, what's your opinion on skipping the winch altogether, and just tilting the boom tip down to ground level, hooking up the truss, and tilting back up near vertical? I raised a ~300-lb. homemade parallel chord truss for a pole barn that way, but unlike you I only had to go a few feet higher than what my bucket could reach, so the boom was a simple 8' length of 4x6 post. Your boom looks significantly longer than that, so presumably your FEL would be feeling quite a bit more torque.
Josh
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
