FEL Roadscrape
   / FEL Roadscrape #1
demote
Georgia
Mahinra 2810 HST
I used my FEL for smoothing the driveway once and made it somewhat better but wondered if I should be investing in a boxscrape or with a little more practice, I can do a good job using the FEL? The tractor is at the dealer right now getting a MMM installed so it could be awhile before another attachment can be added.
Thanks,
Danny
P.S. Also while at the shop, I'm having three hooks welded to the bucket inspired by the posts I've read here. Thanks again.
   / FEL Roadscrape #2
</font><font color="blue" class="small">( I used my FEL for smoothing the driveway once and made it somewhat better but wondered if I should be investing in a boxscrape or with a little more practice, I can do a good job using the FEL? )</font>
In my experience (maintaining 1300 ft of gravel driveway/road for the last 3 years) a box scraper blows away what you can do with just the loader. For one, you can tilt one edge of the box lower to put a crown on the road. This is tough to do with a loader. Also, once you get the hang of it, it's easy to "erase" potholes, momve and level the gravel and generally get a nice smooth finish with a box scraper.
Note: it does take some practice to get good with the box scraper, and it can be frustrating until you do.
One recommendation: if you have a lot of driveway to maintain, or otherwise anticipate a lot of use out of your box scraper, hydraulic top link and tilt cylinders ("Top 'N TIlt" or "TNT") are a great addition. If you won't be using it that heavily, the TNT is probably not worth the expense (though I have ended up using the hydraulic toplink quite a bit when brush hogging).
John Mc
   / FEL Roadscrape #3
I have about 1/4 mi. of driveway to maintain. I have used both the FEL and boxblade. Although both have done the job, I found that a landscape rake with guide wheels does the best job.
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
19?? Asphalt Roller (A52377)
19?? Asphalt...
