FEL removal
   / FEL removal #1
West Point, Tx.
Mahindra 6000
Does anyone have a specific procedure they use to remove the bucket on the ML260 ? 6000 2WD. I don't know if it's a KMW or the other manufacturer. How do you tell the difference ? /forums/images/graemlins/blush.gif
   / FEL removal #2
Charlie: You should have received a operator's manual with the tractor for the FEL. Gives instructions on "take-down". As far as who made it, My 6000 4wd came with the ML264 made by KMW. There is a manufacturer's label right at the pivot point for the arms that raise the loader. I have no complaints with mine (except that when it was assembled one of the hyd. hoses needed and extra 1/4 turn where it connected with the lift cyl line). I put a HD toothbar on it and its somethin' else. Mind you I don't baby this this tractor at all like I see some of the guys on these boards (right now its hard to tell what color the thing is due to mud buildup....) BobG in VA
Set Yield 360 Y Drops (A50514)
Set Yield 360 Y...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
