FEL "problem"?
   / FEL "problem"? #1
Ron25
Bronze Member
So far my home fab'ed loader has been working fine BUT as I was afraid of it might be to much for my 1910.
When I have even the slightest incline I can barely climb it. And if the front wheels get any lower than the back and when I reverse it'll hardly move. I have to be very careful or I'd be stuck. This is without a load and I have no wheel spin.
The other day I hooked up the tiller and as soon as it touches the ground the tractor stops.
I'm thinking other than a weight problem, it's clutch trouble but don't have any squealing or anything. Is there a way to adjust it other than the pedal play - don't think that's the problem. What's behind the plate on the housing on the left? I have to remove the FEL to get that plate off.
   / FEL "problem"? #2
There is no adjustment other than pedal play. If it slipping , you probably won't hear it squeal, but you may smell it. I can supply you with rebuilt or new parts for it.
   / FEL "problem"? #3
Are the wheels spinning when it's stuck? If not, it's likely clutch. If so it's traction. I put calcium in my rears on my TL2100, it went a long way toward resolving my issues. Tire chains helped as well.
2000 Waba Commercial Trailer (A51692)
2000 Waba...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
