FEL operation on 2305
   / FEL operation on 2305 #1
woodsleeboy
ontario, canada
I was just wondering if anyone else has had any trouble with the FEL on their 2305. I'm not sure if this is normal or not but the curl/dump on my loader seems to be really "touchy". It seems that when I want to dump it hesitates for a few seconds before moving, and when it does move, sometimes it dumps fast and somtimes slow. I know there are two positions on the svc for dump mode fast/slow, but I don't think it should be that hard to find them. Also when I back blade or pull back on a pile, the bucket sometimes doesn't hold it's position and floats, almost like the hyd. oil is leaking back. I used to use a FEL on an 855 and don't remember this ever being an issue on it. I guess I'm just wondering if this is something I just need to get used to, or something I should call the dealer on. If this is normal operation, than I can say it's pretty disapointing
   / FEL operation on 2305 #2
Could be air in the circuit(s). Run it all the way up, all the way down a few times. Curl all the one way, then the other as well.
If that doesn't fix it, have dealer check the contol valve.
   / FEL operation on 2305 #3
I've noticed a similar problem on mine. It seems to happen at low RPM. I kick the throttle up a little and it's fine.
   / FEL operation on 2305 #4
Does it changes depending on if you're engaging the hydro or not? With the drive disengaged, the controls should be consistently crisp.
   / FEL operation on 2305 #5
I have also had weird things happen when moving mulch with mine. If I let the control lever return to it's original position and then move it, all works fine. I don't know but I have noticed it sometimes dumps fast and sometimes slow. When it's slow I stop and start over and that seems to work. /forums/images/graemlins/confused.gif
   / FEL operation on 2305 #6
woodsleeboy,
Coming from a JD755, so I know what your frame of reference is, the loader hydraulics on the 2210/2305 are nowhere as responsive as you are used to. Just be patient, the tractor will get the job done; albeit a little slower.
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
