FEL ON A 750
   / FEL ON A 750 #1
22261
MA.
I finely got my old 750 up and running. i was wondering why the FEL hydrolics are so so. is their some adjusment i can make or mayebe a new pump what do you guys think ?
   / FEL ON A 750 #2
What do you mean by "so so"? Slow? Lacking power? Does your tractor behave differently than another, similar machine?
Depending on your situation, it could be weak pump, restricted lines, low/bad relief valve or just the way the tractor is /forums/images/graemlins/smile.gif
   / FEL ON A 750
i mean they are slow in the going up. im looking for sugjestions to speed them up
   / FEL ON A 750 #4
The 750 never had very fast hydraulics because of a small pump, especially if you have power steering. If it is slower than it used to be , chances are you have a resticted sump screen or filter. I would drain the oil and clean the screen first. If there is any water or condensation in the oil, the screen gets a coating of "slime" on it and restricts flow. If that is the case, an oil change for the transmission is in order. If filters and oil check out, then chances are you have a worn pump. How many hours are on it?
   / FEL ON A 750
it has 1997hrs
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
New Wolverine Push Blade (A53002)
New Wolverine Push...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
John Deere 1025R with Loader (A51573)
John Deere 1025R...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
