FEL on 5045D
   / FEL on 5045D #1
jed1894
Georgia
John Deere 5045D
It was recommended that I ask you guys this question:
I'm thinking about putting a 512 loader on my 5045D. According to the specs, it should pick up the largest of hay bales. I understand the ballast and tip over issues, I'm just making sure the loader will actually pick up the bales high enough to double stack them.
Anyone with experience?
thanks, jed
   / FEL on 5045D #2
It'll pick up 1850lbs 32" out from the pivot pins, which would be about the center of the bale, 114" high, so I guess it depends on the size bales you are using. I wouldn't forsee it being a problem, as even with 4x4 bales you would only need to pick it up 6 1/2 feet or so to double stack them if you stab it in the center. It'll pick up 2300lbs 6ft up at 31" from the pins so unless you have some abnormally large bales, I think you'd be fine. With a lot of ballast of course.
   / FEL on 5045D #3
Is this just a 2wd machine? If it isn't why not spend the extra $500 and get the 553 loader and gain a little lift height?
   / FEL on 5045D #4
5045d is 2wd, 5045e is 4wd, 553 would definitely lift more.
   / FEL on 5045D
Thanks....ordered the 512 today. Don't want to invest too much in loader for a 2wd. Just wanted to make sure I could get the hay off my low trailer and into the horse pen.
thanks, jed
   / FEL on 5045D
Got another question:
Does anyone know the weight of the 512 loader. I have the weights installed on front now and my dealer is going to sway them for some back wheel weights for ballast. But, if the bucket is empty and I'm bush hogging, etc. I don't want it to bounce (like it did before the front weights were added). Does the FEL weigh enough to off-set this bounce?
thanks, jed
   / FEL on 5045D #7
How much front weight did your tractor require on the front to prevent the bouncing?
I have 420 lbs of front weight for my MX6 and works great, I suspect you could do the same without the bucket attached using just the loader frame.
   / FEL on 5045D
I'm not sure....I'll be at the farm later and I'll add them up. I believe I have 6 of those weight plates plus the mounting bracket. I'm sure the loader will at least weigh as much.
thanks, jed
   / FEL on 5045D #9
You are going to LOVE that rig! I've had my 5045D/512 for a year, and I find more uses for it every day...
Jim in Texas
   / FEL on 5045D #10
I have the 5055d with a 512 loader. I use the loader for lifting logs. I had a big 30+ inch wet red oak log that I tried to lift with it. I looked online for a calcuator and it estimated it at 2500 lbs. The tractor and loader didn't seem to have any problems lifting it. So far I have been able to either lift what I wanted or the back of the tracker came off the ground. I'm still working on getting enough ballast. I have a 6' tiller that helps but I'm going to try for about 1500 lbs of concrete to make sure I have enough. The only thing I don't like about the two wheel drive is trying to move things without enough ballast. It doesn't work well especially in the snow...
Also, I have a big mower as well. Once you put the loader and bucket on you will not have any bouncing at all.
2016 Hyundai Sonata Sedan (A50860)
2016 Hyundai...
2019 Ford E-350 Super Duty Knapheide Enclosed Service Van (A48081)
2019 Ford E-350...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2022 Kawasaki Z125 Pro Motorcycle (A48082)
2022 Kawasaki Z125...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
