FEL Lubrication
/ FEL Lubrication #1
ericbx1500
Michigan
BX2380, scotts 48
Looking in my owners book(la181)is say's to grease the fittings every 10 hours of use which I do. But it also says lubricate joints of control lever linkage every 10 hours /forums/images/graemlins/confused.gif What joints are they talking about /forums/images/graemlins/confused.gif
/ FEL Lubrication
How do I access it. Do i have to pull the cover off? Is there a zerk fitting?
/ FEL Lubrication #4
Take the cover off and spray the mechanisms with white lithium spray grease. I only do it about once every 50 hours or so though.
/ FEL Lubrication
I’m assuming we are talking about the black cover that’s held on by four Philip head screws. Looks like I have to remove the battery cover (radiator pre screen) to access the inside lower screw?
/ FEL Lubrication #6
Here is a picture I borrowed from <font color="orange"> Kubota's </font>site. The driver has his right hand on Joystick. Lube the linkage at other end of stick. Yes you may need to remove cover.
/ FEL Lubrication #7
What's the trick to getting off the cover on the LA 402 loader?
I sure would like to grease the linkage, now that I know where it is /forums/images/graemlins/crazy.gif, but I can't figure out how it is clipped on.
Lou
/ FEL Lubrication #8
My FEL has a metal cover over the linkage. It can be removed by removing 3 bolts that hold it on under the valve mounting bracket.
/ FEL Lubrication #9
My loader valve has a black plastic cover on top. It looks like I have to take that off to get to the linkage, but I can't figure out how it is attached. I'll take some pictures but it will be about 2 weeks.
Lou
/ FEL Lubrication #10
I copies this from the 402 parts list. Looks like the plastic one use the same bolts as my metal cover. Hope this helps.
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
John Deere 5045E for sale
John Deere 5045E...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
Transfer tank (A61567)
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
