FEL knob removal?
   / FEL knob removal? #1
e-wa
Installing my 3rd function knob on my XG3135H, how does the stock FEL knob come off?
   / FEL knob removal? #2
I'd say just twist it off. In the instructions for installation they talk about lock-tite so that is what you're up against. But that's how I would attack the problem if I was in your situation.
Hope this helps.
   / FEL knob removal?
Thanks for the reply, tried twisting and felt I was going to break it. I will put some heat on it to loosen the Locktite
   / FEL knob removal? #4
Well you might break if is the heat doesn't do it but then you can put a new custom one on with the "proper" jam nut!! I ran into this on my backhoe controls and decided to work around the knobs for now as I read about the Locktite. Good luck!
   / FEL knob removal? #5
You should be able to back the jam nut off and unscrew it. Mine loosen itself up all the time
   / FEL knob removal? #6
That's the issue. It doesn't have a jam nut. Locktite from the factory assembly is what is used instead of th jam nut.
   / FEL knob removal? #7
Does it have wrench flats? Have you tried vice grips? I would avoid heat each line has a coated washer on each side of the fitting, plus there maybe orings on the internals
   / FEL knob removal? #8
If your joystick looks like the one pictured on the LS site for an XG3135 you have to cut the zip tie at the bottom of the rubber boot and lift the boot to expose the locking jam nut.
   / FEL knob removal? #9
Mine does not have that boot it just a stem with a black knob.
   / FEL knob removal? #10
If you don't mind me asking, where did you buy your 3rd function switch and is it part of a kit? How difficult was installation? Never been good at puzzles. Thanks
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
2019 Western Star SF4700 Dump Truck (A47384)
2019 Western Star...
2014 Chevrolet Express 2500 Cargo Van (A50323)
2014 Chevrolet...
40' CONTAINER (A51244)
