fel joystick control change over
   / fel joystick control change over #1
1bushhog
I would like to change out the fel control hyd. joystick to accomadate a grapple attatchment. What I am looking for is a new joystick that has 1 more hyd. hook up and control handle to opperate the grapple cylinder on the fel bucket. Anyone know where I can find something like this for a Mahindra 2015 fel? The grapple attatchment is a home made item. I am trying to make the hyd. hook up as cleas as possible.
   / fel joystick control change over #2
That sounds like it might be an expensive undertaking just replacing the original joystick. I think most tractors have a power beyond port that you can add an additional lever to. I understand your desire to make it clean, but those controls are pricey! It might be possible to add a second lever to the same mount to one side of the original joystick with a fabricated mount. Maybe a local shop could help you do this?
   / fel joystick control change over #3
The Prince SV stackable valve can be used as you describe. It can be configured with 3 spools with a joystick controlling 2 of the spools for the loader.
Here is a link to the Prince site. Click on the Series SV valve catalog pages for complete information. Several TBN members have used this valve with great success.
Prince Directional stack valves
   / fel joystick control change over #4
1 BUSHHOG, If you are up to building a bracket for the valve you can use a tisco# HV4010 valve & HV4940 bower beyond sleeve to do your job. It will require som plumbing work and bracket building. Being I am not very computer savy, if you call me at 585-343-0770 I will explain how the plumbing is done and fax you a drawing if you want. Good luck
GLaWall
Your Mahindra Tractor Dealer
Batavia, NY
   / fel joystick control change over #5
It is also possible to put an electric valve up on the front of the loader. When a button is pushed the bucket valve will activate the aux. attachment. I have seen this used on a round bale grabber.
Will
   / fel joystick control change over #6
Run the grapple from a rear SCV and use the valve on the tractor.
Case 830 Tractor (A50514)
Case 830 Tractor...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
