Loader FEL JoyStick Assembly Cable Replacement
   / FEL JoyStick Assembly Cable Replacement #1
Kubota Tee
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
Hoping someone out there can help me with this repair or at least share some related experiences.
My wife was using our Grand L5740 HSTC-3 tractor yesterday for moving material in the FEL. At some point, the FEL stopped working in the down position and only went up at a snails pace. The curl function was still working as normal. She was smart enough to stop what she was doing in order to avoid any further damage.
When I got home, I started investigating and found the Joy Stick control very lose in the down position, almost as if there was no connection. Thinking that the linkage may have broken, I started following the assembly cables to where they connect to the hydraulic valves and found that the up/down cable was not moving anything. Of course, this was after removing the rear tire and the access panel within the wheel well. I was able to operate the valve manually, so that seemed to confirm that the hydraulics were fine and it was a linkage/cable issue.
I haven't taken apart the cable yet, but have identified the Kubota Part Number as TD270-35252, Loader Valve Lever Assembly Cable.
Here are some of my questions . .
Do these cables just where out / break at times? Is this a relatively normal repair?
How difficult is it to change this cable? Any special tools needed?
Is this a symptom of something else - operator issues? I did purchase the tractor used with approx 400 hours on it. It currently has 540 hours.
The cable is not that expensive - $120, but I want to make sure I'm not getting myself into anything that I may not be able to complete.
Any / all thoughts, suggestions, comments are welcomed!!
Thanks!
I was able to successfully replace the assembly cable. It was not a difficult job - just a few tight locations that would have been better served with a stubby wrench versus the full sized wrenches that I have. Nonetheless, I was able to get the job done with little interruption. The hardest part was removing the interior trim and the right rear tire.
After removing the trim and tire, it was easy to remove the access panel and gain access to both ends of the cable. Before I installed the new cable, I laid the new one along side the old one to compare and contrast them. The old one was definitely broken at the lower end where it connects to the valve
I use the float position all the time during the winter for snow plowing and will try to remember to be a bit more gentle when engaging the float position in the future.
One other note - when researching the part, it appears that Kubota issued an engineering change at some point - I just hope the new ones are stronger than the ones that were used during the factory install. Also, this part and assembly is not included in the factory service manual.
Hope this post is helpful when someone else has the same situation.
   / FEL JoyStick Assembly Cable Replacement #3
I must have screwed up because I replaced my broken cable without removing the tire. The cost is high but worse for me is my tractor was down 11 days while the dealer got the cable. I could drive it no problem, but that involved getting out and working the valve by hand so the loader job I contracted to do was on hold. Others have said here they had their replacement cables made locally but I have no idea where to go anywhere within reason. In saying that, yes, I did find several people here have had that cable fail.
   / FEL JoyStick Assembly Cable Replacement #4
Do you think the failure is due to an improperly adjusted cable? (Assuming it is even adjustable)
Just wondering if there is something that can be done/checked before failure occures.
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
2007 KUBOTA M5040F TRACTOR (A51243)
2007 KUBOTA M5040F...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
