FEL hydraulic connection to JD950
   / FEL hydraulic connection to JD950 #1
Rakzoo
South Bend, IN USA
John Deere 950
I have acquired a used 5' foot FEL to retro fit onto '78 JD950. I should be able to weld any needed brackets to couple the loader to the tractor. Can anyone advise on how to proceed with the hydraulics? Where to tie into? Concerns?
   / FEL hydraulic connection to JD950 #2
If I remember right, you have a block on a line that you can split the hydraulics under the seat on the right hand side of the tractor.
The loader frame bolts to the underside with pre threaded holes. Shouldnt be to hard to make something to fit that.
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
