FEL "Front" hoe or thumb ?
   / FEL "Front" hoe or thumb ? #1
bcarwell
Austin, Texas
Kabota 7500DT
I have seen a lot of plans/kits/attachments for back hoes attached to a three point hitch.
Since a FEL already has some controllable movements, has anybody ever seen some sort of "front" hoe attachment, e.g. something that attaches to the FEL with or without bucket for digging, using auxiliary hydraulics and the FEL movement controls ?
Or is the movement of a FEL so different from a backhoe as to provide no usable movement or anything else useable for that matter other than the moveable arms to attach a hoe to, the tractor mass and mobility, etc.
And come to think of it, I've also seen static "thumbs" for back hoes using the movement of the hoe bucket for grasping against the thumb.
Has anyone ever seen a similar thumb below a FEL bucket for grasping against, using the movement of the bucket against a static lower FEL "thumb" ? ? I have seen hydraulic grapples that attach to the <top> of the bucket, but they use auxiliary hydraulics.
Farmer Bob
   / FEL "Front" hoe or thumb ? #2
Bob ... Power Trac machines have front monunted hoes .. otherwise we call these machines excavators! You can put a grapple on a loader, as a big horizontal thumb. I've also seen a backhoe style thumb on a loader as well.
So yea, there out there! Quite useful if you can arrange the hydraulic plumbing ...
   / FEL "Front" hoe or thumb ? #3
Bob,
Just yesterday I saw a Bobcat with a backhoe mounted up front instead of a bucket. Adding a grapple to the front bucket is like adding a hydraulic thumb to the backhoe. Just flip the backhoe bucket and thumb upside down in your mind and there's the front bucket and thumb (grapple attachment.
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
