Front-End Loader FEL for MF 1020
   / FEL for MF 1020 #1
BBB
Bronze Member
I have bought a used MF-1020. It does not have a FEL. I am thinking about adding one for light duty work around the house.
Any suggestions? I have used large backhoes etc so I know how to operate it but I don't know what to buy. Is this tractor big enough for a FEL?
   / FEL for MF 1020 #2
I have MF 1020 with a factory loader. I bought the tractor with 500 hr. from a dealer and had them add the loader. I got it around 1993. The loader is easy to remove, no tools necessary. Flip two levers and back away with bucket on ground and pull joy stick backwards as if raising bucked but front support goes to the ground to support, the frame. Shut tractor off and disconect the hydralick from bucket frame and then reconnect on tractor side. The joy stick stays with the FEL.
   / FEL for MF 1020 #3
There are quite a few FEL manufactures. I would stick with a name brand. That way if you ever need parts you can get them. Talk to a MF dealer and see what they install. There are some on Ebay if they are in your area. Once you get a FEL you will wonder how you ever got by without it.
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2019 CATERPILLAR 336 EXCAVATOR (A51242)
2019 CATERPILLAR...
UNUSED 40' CONTAINER (A51244)
UNUSED 40'...
