Loader FEL for a Ford 2310?
   / FEL for a Ford 2310? #1
cedarparker
Central Texas
Jinma 284, Ford 2310, Ford 6600; Ford 8N
I just bought some property that comes with an option to buy a Ford 2310 that I haven't even seen yet up close because the current owner has it in for a power steering repair. Not even postive if it's 2WD or 4WD yet.
I do know it doesn't have a FEL, and if I buy the 2310 I'll be wanting to add one. So I'm doing some research so I'll be ready to jump on it (or not) when decision time comes.
Koyker doesn't list the 2310 in their "loader search" but they do list the 2110, and suggest the Koyker 220 loader for it. Is the 2110 similar enough that a Koyker 220 "ought to" fit?
Or, any owners of a 2310 with FEL that would care to recommend a make and model?
Thanks, and All the best,
Jeff
   / FEL for a Ford 2310? #2
Jeff
no a 2110 was a compact tractor and a 2310 was a regular utility tractor the loader off of a post 65 2000,3000 the 2600, 3600 and 2310 was all pretty much the same tractor so will need a loader for one of them
Thanks, whodat!
I see from the Koyker website that a Koyker 220 fits the 2600 and 3600 so there's a good chance a 220 will fit the 2310.
Did some more web research today and it seems that there are (used) Ford loaders that can be had as well. Are the Ford loaders any good?
   / FEL for a Ford 2310? #4
yes u will need to get the brackets for a 2600 or 3600 not the ones for a 2110 and u should be good to go
the ford loader are some good loaders but when buying used u would wont to check the pins and bushing on any brand and for welds broke i believe a ford 777b loader fits it and i know a 7209 will fit
and where are u located because somebody on here might have one or know where one is at there is a lot of dealers that get on here that might can help u find one
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
