FEL DROPS OVER NIGHT
   / FEL DROPS OVER NIGHT #1
JMP
IL
BX 2200
PURCHASED A NEW BX2200 THIS JUNE. FOUND THAT IS I LEAVE THE LOADER UP OR THE 60MMM, THEY DROP OVER NIGHT. IS THIS COMMON? ANY HELP IS THANKFULL.
WOLFMAN.
   / FEL DROPS OVER NIGHT #2
I would say that some dropping is normal, especially overnight. Some people believe there shouldn't be any, but I look at it this way. The hydraulic control valves always have some seepage, after all there has to be some clearence between valve and valve body for movement and lubrication.
In fact, when parking for any extended period of time, I make it a practice to drop all implements to the ground and move the hydraulic controls (with engine off) until I've released all the pressure in the circuits. Leaving the circuits loaded increases the wear.
Dave Perry
   / FEL DROPS OVER NIGHT #3
Over night is not unusual and well within the manufacturers specification. Unfortunately they do not put check valves on loaders and they can't to the best of my knowledge which would remedy this. All hydraulics should be left in the down position.
   / FEL DROPS OVER NIGHT #4
Art,
Why couldn't you put a check valve on a loader? I have been thinking about that for a while. But if it would creat a problem I don't want to do it.
   / FEL DROPS OVER NIGHT #5
On my B2150 the loader drops an inch or so every 30 minutes, but the rear 3-point hitch will hold implements up for days. Note that the loader drops at this rate regardless of whether the engine is running or not; when mowing for several hours I have to occasioinally raise the FEL so it wont hit the ground.
Note that it is dangerous to park the tractor and leave the implements up, ESPECIALLY WITH CHILDREN AROUND. A year or so ago I made the mistake of leaving the FEL up high enough so that I could sit in the bucket while waiting on someone to come help on the project I was working on. I let a neighbor's kid sit on the tractor and pretend he was driving it. After a while I sat back down in the bucket just in time for the kid to lower the bucket. Fortunately I was able to quickly stand up and clear the path of the dropping FEL bucket and didn't suffer any harm...but it was close. I really fear what would have happened had I not been there would've been a second kid around the bucket when it came down.
Kelvin
   / FEL DROPS OVER NIGHT #6
Check valves can't be used at all when you need float and are not used when feathering is needed.
   / FEL DROPS OVER NIGHT #7
Definetly -I ALWAYS (almost) drop everything then wiggle the joy stick to make sure nothing can move. several hundred pounds poised to drop from just a bump can do alot of harm
   / FEL DROPS OVER NIGHT #8
I guess some do and some don't. I have a friend w/a 2900 'Bota and his drops as when I had a 2900 mine didn't but then again I had a Woods loader on mine. I now have a 4610 and I must be lucky because you can leave raised overnight and the next day it doesn't appear to have fallen any.
   / FEL DROPS OVER NIGHT #9
"PURCHASED A NEW BX2200 THIS JUNE. FOUND THAT IS I LEAVE THE LOADER UP OR THE 60MMM, THEY DROP OVER NIGHT. IS THIS COMMON? ANY HELP IS THANKFULL.
Your manual probably states to lower all implements upon shutting down the tractor.
<font color=red>This is a basic safety precaution. </font color=red>
Why would you want to leave your FEL up, anyway?
   / FEL DROPS OVER NIGHT #10
OK, so other posters have relayed the idea that implements should be left on the ground, and the pressure in the FEL circuit released, when you leave the tractor overnight. Will the 3pt and FEL drop if you don't - yes, but seemingly at various speeds depending on the state of the tractor hydraulics, and the manufacturer's specs. The FEL on my 3410 takes many days to drop (I left it up by mistake - never have left the 3pt up, so can't comment). No big deal.
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
1 pallet of miscellaneous hoses (A53117)
1 pallet of...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
