TimBuck2
Bronze Member
I have a Kubota L4310 HST with a FEL. When I plowed this past Sunday I had a problem with the loader valve.
The boom won't raise when the lever is pulled all the way back; if I pull the lever past about 3/4 of its throw the boom stops at what ever height it is at.
I can raise the boom slowly (up to about 2/3's speed) but as I pull back further on the valve, once I hit a certain point, the boom stops. At the point where the boom first stops, there is pressure to the cylinders (slight lag in the engine, and the hoses to the cylinder jump and straighten out), but if I pull all the way back, the pressure is released to the extent that the hoses slacken and no lagging of the engine. The boom does not fall.
All other hydraulic functions for the FEL and the hydrostatic drive work as they should, and the loader appears to have normal power for lifting.
The 3-pt hitch (power beyond from the FEL valve) seems to work as it should (raises very slowly when the FEL valve is in that stopped - pressure position described above, but raises at normal speed when the FEL valve is pulled all the way back).
This is a HUSCO FEL valve. The tag has fallen off, but I believe it is a 9210 series valve. Not sure if it helps in diagnosis but ...., the bucket dipper cylinders still operate when the boom valve is in the float position.
Lastly, Sunday was in the mid- to upper 30's, relatively warm and sunny when I plowed, so I don't believe this is a freeze problem.
Thanks for any ideas how to approach this.
