fel control on b2910 is leaking
/ fel control on b2910 is leaking #1
closs2sx
Bronze Member
The quick connects have never been taken off as the loader has never been off there is 230 hous on it I have checked the fittings for tightness and they are tight it leaks a little over night while its shut off the leak is slow enough I cant tell if the quick connects are leaking or not
/ fel control on b2910 is leaking #2
The quick connects on my b2710 leaked a little when I disconnected them and leaked a little over night. It must be a little oil in the disconnects draining out has not been a problem since. Next time I'll take off the FEL outdoors.
Steve
/ fel control on b2910 is leaking #3
The FEL valve leaked because one of the fittings had come loose at. Remove the QD's and check each of the fittings left on valve.
