FEL Control Lever Flap
   / FEL Control Lever Flap #1
Anonymous Poster
Epic Contributor
There's a metal flap above the my FEL control lever that you can flip down, where it then prevents the the control lever from going up (forward) and lowering the bucket. My manual doesn't say anything about this. Anyone know what that's for? I can see a safety device for preventing you from raising the bucket, but one that keeps you from lowering it?!?
I think it is all a matter of prespective. If you were standing under the bucket looking up, this prespective could be kind of scary when the lever was accidently hit. /forums/images/graemlins/wink.gif
   / FEL Control Lever Flap #3
The flap is to ensure that the bucket is not dropped. I am wondering if it is OSHA inspired
   / FEL Control Lever Flap #4
I haven't read anything to confirm this, but I always thought that it was for transport use. On a rough road my lever can flop quite a bit, especially if you hit a frequency that reinforces itself and the last thing you want is for your loader to accidentally lower while travelling at road speed.
   / FEL Control Lever Flap #5
You would think they would have a lever to prevent the stick from moving at all. I flop it down when I'm mowing the grass because I tend to get pretty close to my lilac bushes (going forwards and backwards) and they can and have moved my bucket for me. At least it prevents it from moving in three directions.
   / FEL Control Lever Flap #6
<font color="blue"> I flop it down when I'm mowing the grass because I tend to get pretty close to my lilac bushes (going forwards and backwards) and they can and have moved my bucket for me. At least it prevents it from moving in three directions.
</font>
Me, too, but it can be pretty obnoxious when your bucket "magically" winds up in a higher position than you expected when you're on steep hills. Not dropping the bucket is all well and good but having it raise up can be dangerous in its own way...
   / FEL Control Lever Flap #7
The L30's now have a locking lever that locks up all movement of the joystick. Very handy when your doing things around the tractor and your 2 year old is sitting in the seat mimicking everything I do when using the tractor. Other then when he's on it, I never use it. Rat...
   / FEL Control Lever Flap #8
<font color="blue"> The L30's now have a locking lever that locks up all movement of the joystick. </font>
Sounds very nice. Wonder if that would be enough to convince the CFO that I should upgrade to an L30... /forums/images/graemlins/grin.gif
   / FEL Control Lever Flap #9
My control lever makes more noise rattling then the tractor's diesel engine. Does yours??
   / FEL Control Lever Flap #10
my 7800 did the same thing till i took off the cover and tightened the bolt/nut some more
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
