FEL control detents
   / FEL control detents #1
Signa
Upstate NY
Kubota B3200
Just got a B3200 TLB and was reading the manuals the other night. I usually don't bother with manuals, but since it was late and I couldn't actually USE the tractor, I figured this was the next best thing. Plus, this is a big enough piece of equipment, I ought to read the manual first.
Anyway, the loader control joystick has two detents - the stick will be held in place. I understand pushing it forward to the detant to use the float feature. But can someone explain the use for the detent in the far right (dump) position. The manual explains something about high/low flow in the two positions and taking hydraulic power from the valve (assuming some implement other than the FEL). I'm sure someone can shed some light. Thanks
   / FEL control detents #2
It is the "regen" or regenerative function of the dump circuit. Read THIS post for a great explanation.
Also do a search on the term "regen" for a lot more reading.
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
CAT FORKS W/ QUICK COUPLER (A52472)
CAT FORKS W/ QUICK...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
