FEL control adjustments
   / FEL control adjustments #1
ok wireline hand
eastern ok
can the joystick, cable control on the FEL be adjusted. I seem to have a lot of slack in the joystick. Thank you.
   / FEL control adjustments #2
I would start by checking that the pivot for the handle is tight in the housing and also check the set screws that hold the cables into the housing. The control handle pivot should be held in with an allen bolt from the bottom side.
If everything is tight, you should find the adjustment procedure in the loader manual.
Hope that helps,
Ken
TROY BUILT PRESSURE WASHER (A51248)
TROY BUILT...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
Scag Mower (A50324)
Scag Mower (A50324)
