FEL Bypass Pressure Setting
/ FEL Bypass Pressure Setting #1
DeanH
New to your list and the previous posts on this have been helpful. I have a 770 Ford FEL and want to set bypass valve release pressure. Dealer says he doesn't have old information such as this. Is there a conservative value I can set it at? Tractor bypass operates (Ford 1700 series) at 2140 PSI. I noticed another post stating a similar tractor rating but loader which bypass operated at 1800 PSI. Would that be a conservative value to use or do I need the specification for this unit in particular before proceeding? Thanks, Dean
/ FEL Bypass Pressure Setting #2
I have the manual for the 770B loader which was on the 1710 I used to have. The relief valve for the loader is specified at 1600 psi. No relief valve is required on 1910 which is a larger frame tractor.
Hope this helps.
Andy
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2023 Kubota KX057-5 Compact Excavator (A63118)
2023 Kubota...
UNUSED WOLVERINE 3PT QUICK HITCH ADAPTER (A62130)
UNUSED WOLVERINE...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
