FEL bucket curls overnight
   / FEL bucket curls overnight #1
4lane
Bronze Member
Warren, CT
2008 Kioti CK30
When I park the tractor, I lower the bucket to the ground with the bucket in the neutral position (bottom of bucket flat on ground). Lately I've noticed that overnight or over the course of a couple days, if I haven't used it, the bucket will curl all the way to full curl position. It doesn't seem like there is any pressure to curl when the machine is off, but is there some seal/control valve leaking that would pull the bucket to curl position?
   / FEL bucket curls overnight #2
4lane,
If your loader geometry is like mine The main boom is drifting down creating a load on the curl cylinders causing the bucket to curl fully.
4lane,
Thanks oldnslo. I wouldn't have thought the boom drifting would push the bucket from neutral to curl. Seems like an odd directional force, but I can see it happening. Thanks again!
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
1996 Timpte 46ft Hopper (A53472)
1996 Timpte 46ft...
