Loader FEL Air Lock Issue or Not?
   / FEL Air Lock Issue or Not? #1
hailofaguy
Kingfisher, OK
Kubota B3200HSD
I have a B3200hSD w/FEL and recently the factory quick disconnects started leaking. I changed them out yesterday and today when I hooked up the FEL everything works EXCEPT the part when you pull the stick left and make the bucket lift up. I can get the arms to go up and down, and the bucket to tilt down, but the bucket will not tilt up.
My questions are: Do I need to bleed the lines of air or is this a self bleeding system?
I know there is a possibility that one of the quick disconnects might be bad but if its possible I'd like to bleed the system first. If possible.
Thanks for any advice. Mark
   / FEL Air Lock Issue or Not? #2
I would confirm your hoses are actually bottomed out and connected.
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
Wilrich Field Cultivator (A50515)
Wilrich Field...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
2012 RAM 5500 (A52472)
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
