Feedback requested on first tractor purchase, Considering JD 5065M.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #1
tmac196
Temperance, MI
1951 Ford 8N, 1965 Ford 2000, Grasshopper 325D, JD 5065M
I am new to farming and relatively new to owning a 30 acre horse farm. I am currently raising 8-9 acres of mix and grass hay. Our first two seasons, I cut my teeth by hiring and observing (working) for neighbors who cut/conditioned and subsequently baled my hay. I learned much, but realized, perhaps not unexpectedly that this arrangement leads to problems being at the mercy of the contractors schedule. After some consideration, I decided to enter the baling side (I'll continue to contract the hay mowing/conditioning for now) and purchased a used New Holland 565 baler at the close of this hay season. My current tractors are too old and underpowered to run the baler efficiently so I have spent a good deal of time considering what type of tractor to purchase.
Considerations: I farm flat, sandy soil. Minimum PTO HP requirements suggested by NH for the baler is 35, but more were recommended for more effective baler operation. Baler weighs 3500 lbs. and I will pull and load a hay trailer behind the baler. Additional duties for the tractor include light discing 6 foot bush hog, 6 foot finish mower, 6 foot arena groomer and snow blowing during the winter. I do not yet have a specific need for a FEL.
Here are the specs:
2012 JOHN DEERE 5065M
-2WD
-150 HOURS
-65 ENGINE HP,
-5 CYLINDER JD DIESEL ENGINE
-GLOW PLUGS FOR EASY STARTS
-50 PTO HP
-12X4 SYNCSHUTTLE PLUS TRANSMISSION
-16.9-30 REAR TIRES @ 80%
-REAR TIRES ARE NOT LOADED
-11L15 FRONT TIRES @ 80% (3 RIB)
-TILT & TELESCOPIC WHEEL
-540 PTO
-SUPENSION SEAT
-REAR WORK LIGHT
-DELUXE TELESCOPIC LINKS
-TOP LINK
-STABILIZER BARS
-FOLDABLE ROPS
-DIFFERENTIAL LOCK
-TOOL BOX
-TRACTOR IS IN "NEW CONDITION"
-FACTORY WARRANTY UNTIL 6-26-2015
After review of this information, I am looking for your feedback about this specific choice of tractor for my application and experiences with this tractor, in particular. Has this make and model had any problems develop since it's introduction? Am I missing anything? Are there other considerations I haven't thought of?
   / Feedback requested on first tractor purchase, Considering JD 5065M. #2
The 5xxxM's are fine machines. I personally would want more horse power than the 65, because if you decide you want to run a nice disk mower, or a round baler, 85-100 hp would be nice.
Also, if you are going to do any thing where your are backing up allot, like snow blowing, you may like a 16x16 better.
The problems that I recall on this forum and others have been very few with this model. I do recall that there were a couple cases of defective castings that caused the pump to suck air.
Finally, I can't comprehend not needing a loader on any type of livestock operation. Even for things like changing a tire on a wagon or baler, manure/bedding cleanup, putting lime down, etc.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #3
I am new to farming and relatively new to owning a 30 acre horse farm. I am currently raising 8-9 acres of mix and grass hay. Our first two seasons, I cut my teeth by hiring and observing (working) for neighbors who cut/conditioned and subsequently baled my hay. I learned much, but realized, perhaps not unexpectedly that this arrangement leads to problems being at the mercy of the contractors schedule. After some consideration, I decided to enter the baling side (I'll continue to contract the hay mowing/conditioning for now) and purchased a used New Holland 565 baler at the close of this hay season. My current tractors are too old and underpowered to run the baler efficiently so I have spent a good deal of time considering what type of tractor to purchase. Considerations: I farm flat, sandy soil. Minimum PTO HP requirements suggested by NH for the baler is 35, but more were recommended for more effective baler operation. Baler weighs 3500 lbs. and I will pull and load a hay trailer behind the baler. Additional duties for the tractor include light discing 6 foot bush hog, 6 foot finish mower, 6 foot arena groomer and snow blowing during the winter. I do not yet have a specific need for a FEL. Here are the specs: 2012 JOHN DEERE 5065M -2WD -150 HOURS -65 ENGINE HP, -5 CYLINDER JD DIESEL ENGINE -GLOW PLUGS FOR EASY STARTS -50 PTO HP -12X4 SYNCSHUTTLE PLUS TRANSMISSION -16.9-30 REAR TIRES @ 80% -REAR TIRES ARE NOT LOADED -11L15 FRONT TIRES @ 80% (3 RIB) -TILT & TELESCOPIC WHEEL -540 PTO -SUPENSION SEAT -REAR WORK LIGHT -DELUXE TELESCOPIC LINKS -TOP LINK -STABILIZER BARS -FOLDABLE ROPS -DIFFERENTIAL LOCK -TOOL BOX -TRACTOR IS IN "NEW CONDITION" -FACTORY WARRANTY UNTIL 6-26-2015 After review of this information, I am looking for your feedback about this specific choice of tractor for my application and experiences with this tractor, in particular. Has this make and model had any problems develop since it's introduction? Am I missing anything? Are there other considerations I haven't thought of?
A few things I would suggest, if your soil is sandy I would get 4wd, I would get the rears loaded or at least weight on the front cause if it's a round baler you will feel it wrapping the bale (my 5115M would bounce like crazy.) also a 540-540e-1000 PTO would be an asset cause then you have better variety when it comes to attachments. Just my opinion from baling with the 5115M and working in sandy soil as well.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #4
Step up to the 5085M.
The engine in the 5085 and up machines is an entirely different beast from the lower line 5M machines. A lot of more power and torque.
Thank you for your comments. I will operate a small square baler. We do not like round bales for our horse operations for a number of reasons.
I read somewhere that most hay baling is still performed by tractors with less than 50 hp. If this is true, then I am not sure the extra cost and the potential reduced fuel economy of a bigger machine is justified.
While sandy, my soil is dry and flat. The dealer suggested it would be unnecessary in the conditions in which I operate to load the tires on my tractor. Your thoughts?
I have thought long and hard about a FEL. I have read that once you own one, you wonder what you ever did without one. Yet, I haven't needed one thus far. On the other hand, I don't want to make a mistake not considering a FEL and regretting it and taking a loss on a trade up at a later time.
Decisions, decisions...
   / Feedback requested on first tractor purchase, Considering JD 5065M. #6
I think if you could run my 5045E for one day your mind would be made up. You might go for a 5065E or a 5075E to have plenty of power at the PTO but you would find that the loader and the loaded rear tires are just what you need . If you have horses there is sure to be piles to be loaded into the spreader.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #7
+2. Started with 50 HP 2WD JD 5105. Added FEL. Year later traded on a 64 HP 4WD JD 5303 with FEL and really like it. The 5105 would turn a little sharper and quicker, but no way I would go back. Wouldn't mind having both, but if in your position I would be giving the JD 5065E a look. Since the "E" series have the same frame size, if finances allowed I would buy as much HP as I could up to the 5075E. I personally wouldn't don't think I would go less than the 5055E and if buying new or can find used I recommend going with the 16.9-28 rear tires.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #8
Are you talking the fuel pump, hyd., or what? I have a 5085M that I like very much, accept it loses power quickly and suddenly when in a pull. (It doesn't have to be a hard pull either)
   / Feedback requested on first tractor purchase, Considering JD 5065M. #9
Sorry, I should have clarified...the hydraulic pump would lose it's prime then, as the pump would wear, it would take longer and longer to put out proper flow and pressure.
HERE IS THE THREAD There was at least one other here that had the problem as well.
Hopefully your problem is a simple one.
   / Feedback requested on first tractor purchase, Considering JD 5065M. #10
Thanks for the quick reply back arien4720.
I'm pulling my hair out over my problem, but received some good info about check valves in the fuel line. I have yet to have time to check them out.
2017 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A49461)
2017 Chevrolet...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
71058 (A49346)
71058 (A49346)
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
