FD620 engine
   / FD620 engine #1
flyweed
Southwestern Wisconsin
Cub Cadet GT2544 & LX1050
Not sure if this is the write place to post this, but I am looking for a engine for a JD 445. I had the old plastic cam gear go out, and figured I'd pull the cam and replace with the new upgraded steel one. Pulled the engine out and DANG it...this engine self destructed. HOLE in the block, the piston arms broke off, etc etc.
SO..needless to say, I am looking to see if anyone know where I might pick one of these up used cheaper, than the Ebay "remanufactured" ones that are still over $1000.
I'd even entertain the idea of a direct swap with another engine that would fit the space.
Hoping some of you guys may know where I might be able to locate a used one or cheaper alternative.
Dan
   / FD620 engine #2
Can probably find a front mount mower on public surplus for $500 with a good 3tna72 (or bigger and go custom) and make it a 455. It's also a komatsu 3d72.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2020 KENWORTH T680...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
