Favorite motor oil for your tractor?
   / Favorite motor oil for your tractor? #1
lostname
So what motor oil do you use in your tractor and why?
Thanks for any response.
Roy
   / Favorite motor oil for your tractor? #2
rotella
Why? because it is a carry over of when I used to truck all over this great nation of ours and I could get Rotella anywhere in this country. Never had a mechanical failure due to oil.
   / Favorite motor oil for your tractor? #3
Roy, I used 15W-40 Delo 400 for the same reason virgil uses Rotella. They're both rated for diesel engines and both popular brands. I have no idea how much experience you have or what you know about oils, so I may be preaching to the choir, but use an oil that has an API rating that starts with a "C" (that means it's rated for use in diesel engines); used to be CC/CD, but then later kept moving up the alphabet as improvements came about. I was using CH-4 rating a couple of years ago, but I think there are even later ratings now.
   / Favorite motor oil for your tractor? #5
I'll be running rotella non-synthetic for now will probably go synthetic well after break in. Use this in my GM diesel and on the fireboat I run (903M cummings) and have good luck.
On my GM I run synthetic in the winter...gets her spinning faster.
I'm kicking around the idea of synthetic hydro oil too..
Any thought?
   / Favorite motor oil for your tractor? #6
I like synthetics. Only problem (my experance) is if you have a small leak with the regular stuff, the better lubricating synthitic will make it leak worse.
   / Favorite motor oil for your tractor? #7
yes, you're absolutely right about the leak problem.
   / Favorite motor oil for your tractor? #8
For my diesel yanmar, Rotella 15W-40....see all the reasons above....
   / Favorite motor oil for your tractor? #10
I can tell what oil i use in my Freightliner Caterpiller motor. I started out with Rotella, then switched to Pennzoil , and am now using Mobil Delvac 15-40. You can buy it at Wal-Mart for under $6.00 a gallon. The Mobil is the best at not breaking down. I use less oil with it between changes. Just turned 300,000 miles on the motor and no problems.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
40' CONTAINER (A51244)
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
